Front hood won't open!
Hi guys,
A mate of mine has an 08 2S, and the front hood won't open.
Is there any secret handle or pull cord somewhere? I did try a search!
As for him reading the book, I don't know. Thought I'd ask here first.
Graham
Graham
Is there any chance someone was dicking around in the frunk and pulled the child escape handle? It happened to me when I got my car. Unfortunately the way I got it to open was by driving 45mph.
If the handle gets pulled I think you have to electronically release the hood before closing it.
Newbies Hospitality Director
There is a hidden cable, as Adias stated earlier. You have to remove the right front wheel and then remove theplastic wheel well liner. You shuold be able to locate the cable to open the hood.
I don't believe that back up method has changed between the facelifts. If the battery is cooked (your term) you can still put power to the fuse box and then be able to open the front lid electronically.
Actually the pull release is behind the "Driver" front wheel. You have to remove the wheel and the black plastic shroud around the wheel well and located there is a wire pull release that will manually allow you to open the trunk. It takes a bit of force to pull the mechanism open. Ask how I know!. Good Luck
