CTEK battery maintainer questions.
Just needing to install a battery maintainer. I have a CTEK 3300 and it comes with eyelet clips. Can these be screwed directly onto the battery? Instructions are not clear. Not a big fan of electricity/explosions/electrocutions myself.
And, if I just need to use it now for a few days, where can the negative clamp be placed? Not too many parts of the frame visible within reach of the battery.
If anyone had a picture of their setup, I would appreciate it.
I probably should just get a cigarette adapter anyway.
You can use the eyelets for a direct battery connection but the convenient way is to use the cigarette lighter connector. You can get that it HERE.
+1 on the cigarette lighter connector. I had the eyelets installed for half a year before getting annoyed and going with cigarette lighter.
I got mine at Performance Improvements http://www.performanceimprovements.com/
Looks like they have store nearish to you.
I'll put in a vote for the direct connection. I keep my car cover in the frunk so it's very convenient to take out the cover and hook up the battery. I keep the lid unlatched in the garage so I don't have to constantly be latching and unlatching it. (The frunk light bulb has been disconnected) I didn't like the idea of running the lead into the cabin all the time, closing the car door on the cable, or running it through the window as you have to do with the cig lighter hookup. To each his own on that one.
Anyway, here's how I have things connected. It's semi-permanent in that I just put the cap on the connector and tuck it into the battery compartment when not in use. I have a similar hook up for a different CTEK unit on my Audi. On one of them I had to clip one of the eyelets to fit it properly; can't remember now which one.
Thanks for the pics. In order to attach the eyelets, i saw a video which said to disconnect the negative lead from the battery first, then screw the eyelet onto the positive, then the negative, then replace the negative lead onto the battery. Sorry to seem like a total electrical weanie, but can I just go ahead and touch the negative lead with a standard tool to unscrew it? I saw what the guy did on the video, and he survived, so I gather I can touch this without too much risk?
THe main advantage of removing the ground connector from the battery is to prevent an accidental short when you are working on the positive terminal (accidentally having a tool touch the terminal and the car). Other than that, connecting the leads is a no-brainer. I like mine, as all I do is open the hood and plug the charger into the connector. Doesn't seem any more inconvenient than plugging it into the lighter inside. I agree with sigfla, your colour combo is great.
Disconnect the negative first to remove the possibility of a voltage spike frying your ECM.
Any contact from a positive battery terminal to a conductive ground will produce a short (i.e. BIG spark)at the last contact point, even if the negative cable is disconnected.
BD
BD
and don't stand in a bucket of water while doing it!
Seriously though, take precautions. Don't have dangling jewelry on and just take your time. It is not a difficult connection to make.
I still prefer the cigarette lighter method because I can do it without opening the hood. Just 2 seconds and I'm plugged in and can lock up the car to shut all the systems down.
BD
BD
I got the fry marks on an inner fender to show for it. Not a P-car thankfully.
As always YMMV.
BD
Remember you can be the ground connection. Your tool, through you to the vehicle, or the ground itself. That is why rubber workshop mats over the fenders can help, and rubber soled shoes
cig adapter - dead simple...and no risk of death, apparently
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Well, you only risk death the one time while installing the connector
......after that, if you're into the boot anyway like I am it's much easier than snaking the connector lead into the passenge compartment. TEHO.
