997.1 PCM Display Stuck on Song
I know I have read about this issue before here on Rennlist, but was not able to find the right words to complete a succesful search....
After fooling around with the PCM settings as I tried to reset the TPMS following a rear-tire change, I now have the new-wave band Yaz stuck on my PCM display whenever I pick that particular radio station (Jack FM 93.1 in L.A.). I'm not sure if I can reset the PCM so that the add'l info broadcast by the radio station will update of I will be stuck with Yaz until my next trip to the dealer which should not be until December?
I know this has come up before and I am looking for a soultion as to how to make that go away. All the other preset radio stations are fine and display band and song info perfectly?
Any guidance is appreciated. God Bless Porsche.
Finally found the answer after 30 minutes of searching with the right words. Pull the fuse for the PCM. I'll try that this week.....Thanks to those that have posted solutions.
