DIY – GT3RS fabric door pull conversion
Outstanding write up and pics.
Thank you!
Thank you!
Do you guys recall reading the business about the aluminum colored plastic door pulls when they were developing the 997? Apparently Porsche had originally WANTED to included billet aluminum pulls (which we see today as those plastic things) but during crash testing the billet aluminum's weight was so excessive that during a crash the momentum of such mass caused them to move and open the doors. They had to revert back to plastic PAINTED to look as aluminum to keep them from opening by accident.
Porsche should really engineer a solution for REAL alloy pulls in their sports cars ...
great mod! looks like you could probably source the nylon in any color you wanted and get it sewn on correctly...perhaps a bus. opportunity? Plug Guy?
Great write up. I did this mod too. Did it just for the design/looks....which I like. I know some don't. I found it easier to use a slightly bigger drill bit and just drill out the center of those plastic inserts in step 3. No need for the torch then. Then I used bevelled washers with screws that countersink in. If you get the right size, it's a perfect fit right over the plastic inserts. It was a very clean look and held super strong. Highly recommend attempting it.
Check out this link too, which I found very helpful for the door removal and components. This is where I got the idea for the bevelled washers.
http://www.planet-9.com/reviews/caym...r-removal.html
07 RS
98 C2S
97 C4S
77 911S
07 RS
98 C2S
97 C4S
77 911S
Sorry Nugget...
Very nice write up.
I may attempt this too in the future, using the Maritime Blue straps offered with the 964 RS America. However I'll need to craft the Maritime Blue straps onto the 997 specific axel mounts
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Of course you can also choose the other factory colors (Red, Black or Silver), but I like your idea of using one from the 964.
DO IT, DO IT, DO IT, DO IT, DO IT!!!!!
![Name: pull-closeup.jpg
Size: 34.4 KB](https://rennlist.com/forums/attachments/997-forum/1210759d1501381363-diy-o-gt3rs-fabric-door-pull-conversion-pull-closeup.jpg)
Poseur
I think this looks alright in certain cars, but not all. Some appear to look cheapened by it while the more 'boy racer' ones look nice with it. I hear you pay more for the kit if Walter R. used them once before!
I'm installing the red pulls in my 2007 Cayman. I have the complete set plus the carbon fiber covers. However, the newer cars have a different cable end that connect to the new latch than the 1st gen cars. I will have the cable part numbers in a few hours.
Anyone else experience this?
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
I switched out the bottom part of the axle handle (the part that attaches to the inner door panel) from the old axle mount to the replacement axle mount. I hope that makes some sense. This allowed me to not have to change to the new cable pull. I can't take any pics until Sunday.
The hardest part was getting the spring to sit correctly.
