Helmet recommendations
Trying to schedule my first DE and need a helmet. Anyone out there recommend a reasonably priced, comfortable helmet? Also, not having bought one before, I'd like to know where a good place to purchase one might be.
Thanks--
Thanks--
For a coupe, I think a 3/4 helmet is adequate, but you'll see most people wearing full face helmets regardless of coupe/convertible construction. For a convertible or a motorcycle, a full face helmet is the most prudent choice.
A full face helmet offers better protection from fire than a partially open helmet. Regardless of the helmet, get one that meets Snell 2005 requirements (SA2005). There will be helmets with an updated SA2010 designation, but I don't think that they're available yet.
Don't buy a motorcycle helmet for use in a car - it's lining is not required to meet the fireproof standards mentioned above.
Good luck.
Good luck.
Your helmet fit will depend upon your head. A particular brand may fit your friend and be very comfortable, but it may not fit you. Try lots and then get the one that fits snugly but has no "hot spots". You will have to wear it for a number of minutes to be able to tell!
The Penguin King
Full face is so much safer and I highly suggest that. As far as fit goes it depends on your head shape. You really need to go try them on. I do suggest when trying then on make sure the fit is tight because they will conform to your head a little and losen up.
WHich brand is it that tends to not take up as much headroom in the car? I thought one brand or two had a better profile, flatter top or something like that.
As others said, you MUST try helmets to see which fits best. Note, that helmet should fit snug, loose helmet may feel comfortable but won't be as safe.
I HIGHLY recommend OMP helmets! A bit more money than Chinese made stuff, but well worth the cost! They are greatly built, light, and most can be had with extra accessories (different visos, HANS, etc).
I got this one, it's a GREAT helmet.
http://www.ompracing.it/detail.html?productcode=SC723
I just bought my first helmet (also gearing up for DE). You have to go to a store and try a few on... no way around it. The helmets sits completely differently then I imagined and the one I wanted (reviews/large opening for eye glass wearers) was not comfortable/didnt fit well. Ended up with a bell s2r in a size smaller then I thought I needed....
I second the points made by other posters. The old saying goes something like "don't buy a cheap helmet unless you have a cheap head". Look for quality construction, light weight, and comfort. If you wear glasses or even sunglasses, some helmets just don't work very well. I have a Bell M3 Kevlar Pro series. It's relatively light and has room for my glasses. It's OK to buy online from a reputable dealer but make sure you try on the helmet you're interested in first.
I appreciate all your comments and advice. I will attempt to try one on locally, but I don't know where I can do so easily. Also, while the NJ Motorsports Park isn't THAT far away, it's not exactly across the street either. I might have to do this online, but I'll keep up the search.
Based on recommendations from a few people, i picked up a very reasonably priced helmet from HJC.
http://www.hjc-motorsports.com/ar10.htm
My friend got me a really good deal, and I think it worked just fine for the couple events I went to.
also, to add, the more expensive stuff, according to my friend, isn't any "safer"... they can be made of lighterweight advanced materials, have better ventilation systems, and also be HANS compatible... i'm not a hardcore racer, so I don't ever envision using a hans system...
there is a good article about helmet options in this month's car and driver.
Also, www.ogracing.com will rent you a helmet for a weekend, then you can experiment without having to spend all the money at once....
JO
JO
I have used Arai helmets for all (dirty bike, roadracing motorcycles and DE PCar events) my motorsport needs. Arai is simply the best you can buy.
http://www.araiamericas.com/default....ts/auto/gp-6rc
