clutch issue
Total bill: $1,700 and some change. Included:
Inspect hydraulic system
Remove and reinstall transmission
Replace clutch disc, clutch cover, and release bearing
Replace flywheel seal
Surface flywheel
Top off oil
Not bad...
-T
Surface flywheel
Top off oil
Not bad...
-T
Yes. I had them check the IMS to see if I should do the new install while they were in there. They said they saw no signs of potential wear. Hopefully, they assessed it properly.
There were no signs of leaks anywhere related to RMS or otherwise.
So far so good.
-T
So far so good.
-T
