Unusual a/c behavior...
Basic Sponsor
Ambient temp outside 78.
Early morning start up.
A/C set to AUTO, 65
Driving out of neighborhood, windshield begins to frost up a bit from a/c out of defroster vents.
Select the ‘right arrow’ button to the right of the 'auto' button to stop a/c from all vents and throw the a/c out of center dash vents only, to reduce windshield frost…
And the a/c stops running!
Fan continues to blow, but you can tell the compressor is off and it’s blowing just regular air from outside. Then even more strange – if you hit the a/c OFF button – the air gets very cold again!
Sounds like something in this car’s computer system/control unit is amiss.
Try it on your 997 ('09)....while driving with a/c on auto, hit the right arrow to throw it from only the mid level dash vents...what happens?
Thoughts?
A/C set to AUTO, 65
Thoughts?
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
Basic Sponsor
Yes, consistent. Will get it in shortly for tech to take a look. Just wondering if anyone experienced it and what the solution may have been.
Thanks.
Thanks.
Unique Title
Weird. I've never seen anything like this. I know the car "remembers" the settings you use when you switch between "auto" and "manual" control of the a/c though. Maybe try cycling the compressor on/off (in my car it's the "ECO" button) and see if that does anything?
