First track event in car
Well, did my first track event yesterday in the new (to me that is) car. I have done about 5 DEs in my old 944 turbo over the pass couple years and enjoyed everyone. I went to Nelson's Ledges for a fun day yesterday and had a BLAST!!! In two weeks they are holding the 944 Fest Friday and Sat/Sun is the PCA DE which I will be doing. I have only been to Nelson's one other time about 5 years ago and not much has changed since then. I used the chrono when I was out on one of the sessions and ran 1:20-1:22 average with my best at 1:18.3 during that session. Only timed it for one session because I was always running into traffic so couldn't get a clean lap except for about 3 per session. Overall, VERY fun and can't wait to go back in 2 weeks and actually mess with my tire temps this time. I had set them to the full load when cold, which is like 37/44??... Now after reading around here, looks like I want to keep the rears about 36-39 hot and fronts a couple lbs less then the rear. Anyways, pictures are to follow, so don't worry!!!
Neslon was a shock after being at Mid Ohio several times, but a fun track nonetheless. I was going to go to Nelson with PCA in June too, but will be going to Mid Ohio that weekend. NASA is good to run with too and they have a Mid Ohio event in late July.
. . . . can't wait to go back in 2 weeks and actually mess with my tire temps this time. I had set them to the full load when cold, which is like 37/44??... Now after reading around here, looks like I want to keep the rears about 36-39 hot and fronts a couple lbs less then the rear. Anyways, pictures are to follow, so don't worry!!!
Bled it down to 36/39 hot and kept reducing the pressures a bit after each successive session to keep it at 36/39 hot optimal pressure. The rears would get quite sticky and start picking up a bit tire marbles but for most part 36/39 hot for PS2 worked well for me . . .
