since we are BIG weight reduction guys
Old 05-26-2010, 12:07 PM
niner niner seven
niner niner seven's Avatar
Default since we are BIG weight reduction guys
does anyone just fill half a tank of gas each time, rather than full tank
i suppose you should go full tank on lengthy trips, but if you only drive the carrera a couple times a week even filling half wouldn’t have you stopping frequently for gas
what say you?
Old 05-26-2010, 12:22 PM
RollingArt
RollingArt's Avatar
NO WAY !
That's crazy talk.
You may need therapy.
Phil
Old 05-26-2010, 12:39 PM
machina
machina's Avatar
only for track events, run 1/2 tank and fill between run-groups.
I even drain the washer tank.
Old 05-26-2010, 01:29 PM
brendo
brendo's Avatar
i run a full tank and also leave the passenger seat in the car
Old 05-26-2010, 01:36 PM
At Law
At Law's Avatar
I let all of the air out of the tires.
Old 05-26-2010, 01:37 PM
Mike in CA
Mike in CA's Avatar
I run 1/2 tank of 100/91 octane blend for autoX otherwise fill-er-up! Not a great idea to leave tank half full all the time in winter/cold weather anyway as it increases possibility of condensation.
Old 05-26-2010, 02:04 PM
Edgy01
Poseur
Edgy01's Avatar
I visit the vomitorium before I go racing.
Old 05-26-2010, 02:17 PM
Ucube
Ucube's Avatar
I wear my plastic Timex instead of the metal Breitling.
Old 05-26-2010, 02:44 PM
Quadcammer
Quadcammer's Avatar
Received 1,444 Likes on 836 Posts
well, fuel is about 7lbs per gallon, so you could save a cool 63 lbs with a half tank. That said, the weight is coming off the wrong part of the car.
Old 05-26-2010, 02:52 PM
Alstoy
Alstoy's Avatar
I'm working to loose another 6lbs, so I can get down to 160. But, you do bring up a good point. What are the areas of weight saves? Any of the experts care to share?
Old 05-26-2010, 03:30 PM
Fin Fever
Fin Fever's Avatar
what say you?
no
Old 05-26-2010, 03:39 PM
Mike in CA
Mike in CA's Avatar
Don't know about the expert part, but removing the rear seats/cushions is a pretty easy 25+ pounds. Pretty much necessary anyway if you're installing a harness/roll bar. Replacing stock battery with an Optima when the time comes saves another 10. Sport buckets save about 50lbs total over stock power seats. PCCB brakes save about 40 but they're not a DIY retrofit and they're $$$, although they have other benefits. And of course, lighter wheels will save you an extra few lbs a wheel. Other changes like lighter exhaust systems are available, but IMO there are tradeoffs the further you go into the weight reduction thing.
Old 05-26-2010, 04:25 PM
cbzzoom
Registered User
cbzzoom's Avatar
I start the car in the morning and then take the battery out
In all seriousness, I do remove the manuals and the tire goo cuz those are like 10 pounds together.
Old 05-26-2010, 04:52 PM
robbonds
robbonds's Avatar
wow! 63 lbs is a lot!
Old 05-26-2010, 05:07 PM
winkingchef
winkingchef's Avatar
I have outfitted myself with a carbon fiber skull.
Saves about 20 lbs and as an added bonus, I no longer need to wear a helmet!
Quick Reply: since we are BIG weight reduction guys
