GT3 front sway bar install
Old 05-21-2010 | 01:15 PM
utkinpol's Avatar
utkinpol
Default GT3 front sway bar install
I had no luck finding that on forums but want to try again - could anybody give some pointers on this process?
I am not quite sure what should be dismounted there, did not yet even take plastic pieces off to investigate. I see a lot of parts there in the mid of the car.
Will sway bar simply swirl out or does it require to disconnect all the hoses etc?
Thanks, Paul
Old 05-21-2010 | 03:53 PM
Spiffyjiff's Avatar
Spiffyjiff
after you remove the under trays, from what i can tell...you have to drop the subframe crossmember in the front to get to the bar. i think (??) this means it will require an alignment after. you also might need drop links depending on what sways you have. the back is easier, just a few bolts, drop out old, replace with new.
