Oil Bars & Viscosity
Was wondering how much oil is represented by each bar on the "digital dipstick".
Im trying to avoid overfilling -- and the little notches on the Mobil 1 container are helpful if I can use them to figure out how they relate to the "digital dipstick" guage.
I understand Porsche recomends 0W40. I was reading through old archived posts where folks are using 15W50, and 5w50. Any other Mobil 1 recommendations? I enjoy ethusiastic driving - and want the best protection and performance out of my engine.
Cheers
Cheers
Each segment equals .42 quarts or .4 liters. 0w-40 is recommended for all temperature ranges, while 5w-40 and 5w-50 are ok for temperatures above -13 deg F. I personally wouldn't use 15w-50 since it's not approved for the car and the other grades are readily available.
Use the 5w-50 or at least a 5w-something. The 0w is meant to keep the environment clean at the expense of engine life. The engine heats up faster or something like that so there're fewer emissions.
All due respect, but you're wrong. The 0w viscosity refers to the fact that the oil is thinner at low temperatures than 5w, 10w or 15w, which allows for it to be more free flowing and for the engine to be properly lubricated when it (and the oil) are cold. It's why Porsche recommends 0w-40 in really cold climates but allows for 5w oils in warmer areas. Although 5w oils are perfectly acceptable in the areas where most of us drive, the issue is proper lubrication, and less friction and wear at low temps and when starting. That's the exact opposite of what you are implying.
Just going by what it says in the manual; .42 quarts or .4 liters per segment.
The way I understand it is Porsche goes with the thinner oil (as does Ford and GM) to wind up with lower emissions which make the cars more appealing and meet federal standards better.
I wish I could find the reference, but I doubt I will have the time. I could be wrong but I really don't think so on this one. (friendly disagreement here and BIG desire to get some confirmation either way).
Assuming non-extreme temp range issues use the 5W oil and the engine will last longer but the atmosphere will get more polluted.
But IMO the reasons why Porsche recommended the 0w-40 instead of 5w-50 is in order of most important to least important :
1. Reduction of emissions in the cold start test.
2. Recommending 0w oil ensures that customers use synthetic oils.
3. Better lube performance in the very very cold.
Poseur
Some people simply resist the advancement of technology. The inclusion of an electronic oil level device ultimately results in more frequent oil level checks by owners. If owners had to resort to popping the deck lid and pulling out and wiping off a dipstick, less owners would include that in their daily pre-flight rituals. Ditto for TPMS and tire pressure checks.
Really, how many people checked their tire pressures at least once a week prior to the TPMS capability?
How often do you check the oil (via a dipstick) on your other cars?
Sir, Assuming NO temp extremes: AFAIK, thinner oil means less protection when the car starts up. When engine is cold and clearances are greater so the thinner 0w oil means less protection. Again, not talking winter-ish temp. extremes here, just decent weather in the Spring and Summer USA.
Clearly there are a lot of different opinions on the whole oil issue, and it's been beaten to death before. While there may be benefits emission-wise to using the 0w oil, I've also seen evidence that there are advantages in cold start lubrication as well. I originally reacted to your flat statement that the 0w oil would cause your engine to wear faster. I still disagree. But in normal climates, we're probably talking about tiny differences, hardly worth arguing about.
Bottom line, Porsche filled my car with 0w-40 at the factory, and it's their primary recommended oil. All the opinions and speculation from arm chair experts like us aside, that's enough said AFAIC.
abe
