997.2 warranty issues?
I was wondering what, if any, warranty issues owners of 997.2 cars have experienced.
I had my water pump replaced under warranty at 1500 miles. There was an intermittent "tea-kettle" whistling sound noticeable at idle.
I now have 31,000 miles with absolute reliability and no further issues of any kind. Truly a great car.
wow _ 31,000 miles - looks like you have an 09. thats impressive. i had a radiator pipe (or connector break). leaked the coolant slowly. fixed at around 2000 miles. i have 4100 miles.
Still plays with cars.
The crest fell off my key. Shock horror - I will never buy another Porsche
Newbies Hospitality Director
Bob,
Porsche Quality Control is getting terrible. In order to "make a statement" to Porsche you should send one of your Porsches to me! That'll teach 'em!
Tim, how about I send you a Honda instead You could Porsche badges on it and a Rennlist sticker!
I had to have the defective/improperly installed Targa roof seal replaced when the Puget Sound rainy winters highlighted the leak at the first rainy winter 3 months into ownership in Jan 10.
Also had a slow coolant issue fixed - a small hose/oring between the pump and the engine needed replacing. Took a lot of work to get all the things off the car to get to the point of being able to replace that $1 o-ring. Sounds like coolant leak issues are somewhat common.
I know others have had issues with the high-pressure fuel pump. My 09 has not shown issues yet (at 7500 miles over 18 months) in that area.
I do have a front AWD component grinding at startup issue, and a popping sound from the back end that are as yet not resolved.. I'll be pressing them for a resolution shortly.
HPFP early on, around 1200 miles. No significant issues since then.
A member of our local PCA chapter with a 2010 997.2 C2S has had repeated issues with his Drive Off Assistant and I believe they are replacing his HPFP although it has not failed.
I cracked a weld on my exhaust header. So far that is it in 12k miles and tons of track time. My 09 is a very early car. I ordered it in July 08 and picked it up in September 08.
31K is impressive for a 997.2! I just passed 16K and the only work that I had done other than maintenance was the front muffler clamp fix that was covered by the W913 workshop campaign. No other issues other than the occassional buzz or minor rattle, mostly on rough roads.
