997.2 pcm question
997.2 pcm question
im using my iphone..i press maps button or any other function. I can not return to a list of tracks or play lists without changing to tuner and reselecting ipod
There must be a way to return to track/play lists after looking at the map or whatever..
Thanks in advance
Thanks in advance
The button to use is DISC (yes, its misnamed, but the "NON BROADCAST SOURCE SELECT" would not fit on the button).
It lets you select between CD, USB, AUX, IPOD (if you have the audio interface option)
