trunk lid not lined up with bumper
Hi folks,
I suspect this has been discussed before but I couldn't find any info using basic search. Maybe someone can help.
My trunk right on the front of the car sits just a bit lower than the front bumper. I have noticed this same thing on many 997 pics. Is this something that can be easily adjusted?
Do you need a picture or do you know what I'm talking about?
Thanks,
-T
Thanks,
-T
Noticed on my 997.2 when I picked it up
Fine by me rather than risk a proper seal by adjusting, although it does require some pressure to close the frunk.
i thought i had the same issue. i was staring at the thing over and over until i finally asked the premier body shop what to do. they told me they could measure it precisely and basically bend it a bit. i ended up convincing myself it was the light and not out of line and never acted on it. i have a tendency to believe this isn't that uncommon.
Hi folks,
Thanks,
-T
Thanks,
-T
Some owners have adjusted the front trunk lid higher -- thinking the lid shold be flush with bumper cover -- but this causes a wind noise.
If the lid latches securely and there is no noise and trunk stays drive even when the car driven in heavy rain then leave it alone. Everything is fine.
Sincerely,
Macster.
Mine did the same thing until last week. I was told by a body shop to adjust the height of the black rubber bumper where the trunk lid meets the trunk. There is a bumper on each side. Simply raise or lower by twisting the bumper which screws into the trunk edge.
Try it and see if this does it. It worked for me where one side of the trunk lid was level with the bumper and the other side was a bit off.
The front trunk lid leading edge wants to be lower than the front bumper cover. This is on purpose. The cars come this way from the factory. Visit dealer lot and see for yourself.
You can adjust either side by rotating the bumper stops if the panel is uneven from side to side, but you always want the leading edge of the panel to be slightly lower than the panel ahead. You can see other examples if you walk around the car looking closely. I suspect it is important to boundary layer control and thus achieving the low coefficient of drag we enjoy. However, I'm not an aerodynamicist so take that speculation for what it's worth.
Gary
Be careful messing with the lid's weatherstrip seal. It protects sensitive electronics. IMO, It doesn't appear to be a solid "high-confidence" design arrangement.
