PSE Solenoid Question/Help Please
Nice job Joel. I couldn't find a switch like yours, but mine is a close second I think. For some reason I can't find a photo that I had. BTW, where did you pick up your switched power?
New 997 06S owner here, My PSE is not working so if I'm reading this right vacuum=quiet mode? I have 12 volts switching at the solenoid but always have the solenoid passing the vacuum to the flaps. If I take off the line running to the flaps a tone shift occurs which I assume is "sport" mode?
Brian
Brian
Brian
Brian
This is a good thread to toss this in. I read recently that one of the big reasons that Porsche forces you to select ON for the PSE to be working is that the periodic exercising of that valve is good for it. If you leave it on all the time (and have the OFF option) it could seize in the ON position and then never switch to off like it should. (Of course, it should be cycling all the time anyway I would think because of the noise abatement speeds--imposed by Swiss rules).
I used a 9 volt battery on the solenoid as suggested and can't hear it clicking. The vacuum is passing through the valve all the time so its bad. I'll be replacing it.
Can anyone tell me or show me where the flappers are? I might be wrong but I only hear one side moving when I disconnect the vacuum line?
Installed the solenoid and now the driver side exhaust shifts tone with the button but the passenger side does not. Vacuum lines are good so I'm assuming the bellow is out of the actuator since it moves freely by hand? Is this a common failure in these systems? Also assume based on the location I will have to pull the muffler off to replace it.
Good luck.
