Best Bluetooth option on 997.1 ?
Hello Guys and please help me out with the following.
I have a 2007 911 Targa 4S. It has the PCM Navigation and the 6 disc changer. What is the best way to get the Bluetooth installed, and how intensive is it?
How can you get number recognition on the screen, and are the microphones on the steering wheel active when installing you mentioned solution ?
Any local stores in South Florida that you recommend ?
Thank you
Eric
Thank you
Eric
Options are Tooki and Dension. Do a search, a lot of discussions. I got my own questions too, and I am searching. Tooki seems to have more options, but more money.
Poseur
I really have learned to like the Tooki. Check for my tutorial on how to install it yourself if you have reasonable skills with about 4 tools.
I just couldn't understand how did you wire the microphone (no pics)? Like where is the wire coming out? Back of PCM? Centre console?
Also, what made you choose Tooki over Dension or mObridge?
Poseur
The microphone wire comes out the back of the Tooki blackbox and I simply routed it from the top of the trim piece on the left (near the accelerator pedal) and then up toward the steering wheel area. It was so simple I didn't spend a lot of time documenting it. Everyone should consider trying various locations for the microphone to find one that works best for their application. With a cabriolet, I had to get it down out of the airstream a bit more than the coupes.
Since I am in the same boat as OP, let me ask a few question here. Eric helped me a bit, but I am trying to find out the exact functiionlaities of each of the kits.
I appreciate if owner of each Tooki, Dension, and mObridge can clarify if their Bluetooth supports the following:
Naturally, I searched and couldn't answer the above questions. All of the websites I visited are very vague with limited info, so I think only owners can clarify the specifics. I think it'd be a great guide for everyone who may wanna install either of the kits.
- Stereo auto mute + Phone ring through speakers when a call is received
- Answering calls with PCM phone button (directly - not through CD-player)
- Picking up the phone and dialing with the OEM PCM phone dial-pad
- Caller ID - showing the number of the callee
- Caller ID - showing the name of the callee (even if not entered in addressbook)
- Contact Sync/upload from Phone to PCM (100 entries)
- Speed Dial - dialing directly through phonebook
- Displaying SMS Messages
- Writing and sending SMS messages through PCM
- Displaying Missed Calls/Call history
- If using iPod adapter, ability to switch from iPod to phone when phone rings(just like from CD/Radio)
- Microphone Sound quality - clarity/echo
- Possibility of working with OEM Porsche Microphone
- Unit fits comfortably behind PCM
- Blackberry Bold/Curve Support
Poseur
[*]Stereo auto mute + Phone ring through speakers when a call is received
AUTO MUTE--RINGS RIGHT SPEAKER(S)[*]Answering calls with PCM phone button (directly - not through CD-player)
ANSWER VIA PCM OR MULTIFUNCTION WHEEL[*]Picking up the phone and dialing with the OEM PCM phone dial-pad
BDON'T QUITE UNDERSTAND THE QUESTION...CAN DIAL WITH THE PCM DIALPAD[*]Caller ID - showing the number of the callee
YES[*]Caller ID - showing the name of the callee (even if not entered in addressbook)
YES-I THINK SO (CAN'T BE POSITIVE)[*]Contact Sync/upload from Phone to PCM (100 entries)
YES--FAR MORE THAN 100.[*]Speed Dial - dialing directly through phonebook
ABSOLUTELY.[*]Displaying SMS Messages
DEPENDS UPON YOUR SERVICE. I DON'T HAVE THAT SERVICE--CAN'T GIVE OYU AN ANSWER.[*]Writing and sending SMS messages through PCM
DEPENDS UPON YOUR SERVICE. I DON'T HAVE THAT SERVICE--CAN'T GIVE OYU AN ANSWER.[*]Displaying Missed Calls/Call history
ABSOLUTELY[*]If using iPod adapter, ability to switch from iPod to phone when phone rings(just like from CD/Radio)
DON';T USE AN IPOD ADAPTER--N/A[*]Microphone Sound quality - clarity/echo
DEPENDS UPON THE NUMBER OF BARS YOU HAVE AND PLACEMENT OF THE MIKE.[*]Possibility of working with OEM Porsche Microphone
WILL NOT. [*]Unit fits comfortably behind PCM
CERTAINLY DOES--I PUT MINE IN MYSELF AND IF I NEED TO PULL THE BLACK BOX OUT FOR ANY REASON CAN DO IT IN 5 MINUTES.[*]Blackberry Bold/Curve Support
CAN'T SPEAK FOR THAT SYSTEM. I USE A SIMPLE RAZR.[/LIST]
mobridge does both ipod and bluetooth in one box so if you get it for somewhat about $500 - it`s a good deal. check ebay regularly - they pop up there from time to time.
location of microphone is a pain - any unit requires its own so you will have to wire it to where you want it to be. Mine is in left upper corner as wire comes from a trunk area and I simply tucked it under left column trim.
Basic Sponsor
If you decide on the Tooki, email me for a very special deal....
Dension is discounted on our site as well.
eric@bumperplugs.com
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
Can someone with Dension Bluetooth chime in here please?
I just talked to the Canadian reseller and they said they have discontinued Dension Bluetooth, due to customer complaints. Aparently sometimes the stereo will kick in the middle of a conversation at full blast which is not ideal at all!
@ Eric, was this an issue with Dension earlier models/firmwares?
whichever one you get cheaper is good.
So, if installed in trunk, how did you connect it to PCM?
mObridge (in trunk) --> PCM --> Mic ?
or
PCM --> mObridge (in trunk) --> Mic?
if you had it - you will need to code it off with PIWIS. how and where you put unit into optical ring does not matter, it is still same ring. any spot will do.
As I have navigation DVD in the trunk - mobridge connects to its optical input and power. it does not need any audio inputs and was very easy to install this way - it is actually glued to the DVD unit top surface. ipod lives next to it - it all fits quite nicely there. Only trick was to wire mic cable into cabin from trunk.
Only downside of this location is that good bluetooth reception with phone is only if phone rests on dashboard - see that blue/purple silicon thing on its center, where sport chrono could be? that is where I put my phone usually. or into glove box. if it is left on my belt - sometimes it looses bluetooth connection. so if you usually prefer to keep your phone in your pocket - mount your unit inside - behind the glovebox there is space to fit it.
mobridge connects to the optical ring as any other unit and pretends to be cd-changer. that means also that you will need to disconnect cd changer completely i you have it. if you donot have it and never had - you are OK.
On the mic install, was it easier/harder to mount on top of steering wheel column vs, where you have it?
