Any blown engine in a MY06?
A soloporsche fellow and me are trying to have more information about engine failures
He helped me to do a home custom made IMS bearing support. (It's published in 996 forum)
So we wanted to know if any of you know about someone who suffered a 997 MY06 IMS engine failure, and if there's any 997 reman engine which suffered an IMS bearing failure
I read that Porsche upgraded the IMS in the early months of 2005, updating the IMS tube with an enlarge diameter single row bearing and a 14 mm bearing support/stud.
I don't know if there is any engine like this which suffered a failure, or the issue was fixed.
Could you help me please?
Thanks in advance
Thanks in advance
From forum posts alone it is more common to see complaints about MY05 cars having IMS failure. But several people did see MY06 and MY07 cars in service with IMS related issues as well. But no one yet I think posted about MY06+ IMS failures here or on 6speedonline forums so we can assume it happens not as often as with MY05 and earlier cars.
Issue by itself is 'fixed' in MY09+ cars as they do not have IMS anymore. Any cars prior to MY09 may have this failure. As often will it or will not happen probably depends most of bearing lubrication and single row bearings look to survive a bit better than dual row ones in MY05 and prior cars.
Single row bearing works better than double one, and there is a problem with the design.
as you said, the problem comes from the point It has an IMS...
I did a custom made retrofit/upgrade with an hybrid ceramic bearing in my 996
Tomorrow I'll go to the workshop to get it
http://www.pasionporsche.com/compone...ms-996-36.html
i didn't know if the upgraded enlarged IMS in 997 models could fix the problem.
It's very very important a great lubrication. It's incredible to follow Official dealers maintenance intervals (oil change = 30.000 km)
Cheers,
Joe
When IMS bearing gets stuck and falls apart usually it leads to a catastrophic engine failure and essentially you need to shell out for a new engine.
Look it up on forums, you will find plenty of descriptions about this. MY06+ cars seem to be a bit more stable in this regard. I personally think issue is a bit exaggerated in our forum discussions but you do hear from time to time about people who got engine blown up because of faulty IMS.
Yes, I understand what happens with an IMS failure.
You mentioned in your post that "several people did see MY06 and MY07 cars in service with IMS related issues as well. But no one yet I think posted about MY06+ IMS failures here or on 6speedonline forums so we can assume it happens not as often as with MY05 and earlier cars." Are you saying that you know of documented M97 IMS failures? I think it's telling that we haven't seen one documented here in this forum.
So I did not investigate it too much. I just remember seeing some posts somewhere, here or on rennlist about somebody who saw `07 car with IMS failure. I would say the same - if car has IMS - it may break. Hopefully it happens less often than on `05 cars but probably still may happen. Who knows.
I've done searches on this and other forums in the past and have never seen anyone post about a MY06-MY08 car with this problem. All of them were '05 cars, and even with the '05 it seems kind of rare. That's not to say it coudn't happen, but it hasn't been reported yet on this forum as far as I can tell. Hope it stays that way (knock on wood).
I too recall an '05 owner with this problem saying something about some other cars in the shop at the time, don't recall exactly, but I thought it was other '05 cars. Regardless IMHO, that's hearsay until someone who actually owns the car posts about it.
Me neither. I have seen a number of posts from 05 owners who have experienced failures. Hardly scientific, but a good sign that the M97 engines in the 06-08 cars are holding up.
FWIW, follow this thread on 07' CS with IMS failure.
http://www.6speedonline.com/forums/9...ability-2.html
MY05 (and for a few years before) have single-row bearings. Smaller than the MY06-08 but single nonetheless. Dual-row bearings were phased out several years earlier. There were three bearing designs throughout the 996/997.1 models.
