Help!!! CEL came on tonight....
this evening I got into my 997 C2S ('06, ~30k miles), turned it on and the CEL came on.
earlier today I replaced the battery, cleared the PASM failure codes, and took the car for a long drive. put the car back in the garage. next time the car got started is when the CEL came on.
turned the car off, checked the gas cap, checked the fluids (dashboard dipstick and also coolant), no puddles under the car, etc.
turn car back on, CEL came on again. car sounds fine, drove fine, not in "limp home" mode, etc.
Is this something related to the battery swap earlier today?
full disclosure, car does have an APR ecu flash, no other engine mods (exhaust/intake/etc).
Thanks in advance!
Thanks in advance!
No big deal if it is not flashing. Could be a number of things. Drive it a few days and see if it goes away. If you are worried just go to the dealer and have them clear the code.
update:
CEL did not clear itself. took it to the dealer this morning.
got a call about an hour ago, new ECU is on order from Porsche!
the car kept saying it has a bad O2 sensor, they replaced all of them and it kept coming up, so Porsche recommended replacing the ECU (under warranty, I am told; which is nice since my warranty expires at the end of the month!)
has anyone heard of this problem? was the new battery a coincidence or did that have something to do with the timing or cause of this problem?
It could be a coincidence but the ECU is susceptible to damage when connecting a battery, from surge spikes. Porsche recommendation is negative off first and on last to minimise this as much as possible.
If that were the scenario, wouldn't I have gotten the CEL upon the first start, not the second? That's the baffling thing to me.
What if the APR program screwed some code up? Otherwise, there could be multiple of reasons for ECU to go bad...
I love it, seems completely seamless and noticeably more power. There might be a slight gas mileage penalty, but ~1 mpg (hard to tell if that was the flash or a driving condition anomaly thus far). I know a lot of people go with Softronic, so I'm not sure how they compare.
true, new O2 sensors too whole thing was covered under warranty which was a nice relief!
per the dealer, the new battery was the cause of the ECU failure; apparently it is fairly common. my advice: if your warranty is up soon, change your battery now!
