Gundo hacked mufflers on 997 2" Bypass
I bought a set of mufflers and will do the hack in the next few mos. So, a few questions to those who have done the 997 "Gundo":
I did the "Fister" hack on my 996 and really liked it. Just enough extra rumble without a drone and not too loud.
How does the "Gundo" hack on the 997 compare? Shall I go with 1" or 2" pipe.
Any thoughts from those who have heard both hacks and both sized pipes?
Thanks for your observations and thoughts.
Last edited by Steven B; 03-06-2010 at 07:13 AM. Reason: my usual spelling errors!
My neighbour has heard many exhausts during his time in the Porsche club and has the Motorsports sound option on his 993. He says that the 2" is just right.
Under 3K RPM it's barely noticeable. Over that it sounds quite exotic. I have to say you really can't go wrong with this modification, especially if you're using a spare set of cans. This is THE BEST bang for the buck mod on these cars by FAR.
Newbies Hospitality Director
Steven, I also did the MK II mod (Fister) to my stock 996 3.6L mufflers. If I had a 997 without PSE, I would do the Gundo mod and use the 2" pipe. If you going to do it, this would give you the most sound differential without it being "muffler by-pass" loud.
Hi, Tim, I remember your conversion well, as well as the "deconversion" when you sent your carback (sad). I suspect that the 2" pipeis what I will end up doing, although I wouldloveto hear from someone who had them both (996 and 997).
