Impact wrenches, portable compressors
I'm considering picking up an electric impact wrench for wheel changes. I don't want a high end tool, as I don't use it that often. I've seen cordless ones that look intriguing.
I'm also considering picking up a small 12v compressor to keep tire inflations correct.
Looking for any recommendations/experience re inexpensive versions of these devices. Again, they won't be used very often, so I'm not interested in rugged or high-end versions that a shop would use.
Hey Ken I'd just get a breaker bar. You can even put a pipe on the end for more leverage. Impact wrenches will just wreck things, chip paint, crack chrome, strip threads, IMO. Good for a mechanic who does a dozen tire changes in a day.
Also a speed wrench is nice for getting nuts and bolts back on nice and quick. I use my cordless drill just to get the nuts on or off faster; preceded by breaker bar or followed by a torque wrench of course.
Of course you have to have a torque wrench too.
uninformed gas bag
(contemplating on whether gas bag is one or two words)
There's a lot of guys at the track that buy the cordless ones from pep boys and they swear by them. I have a Longacre that has served me well.
Air compressors? Just for tires? Any diaphragm compressor will do that. If you are looking down the road for more air a recip compressor staring at 7 scfm and a 30 gallon tank would be nice.
http://www.sears.com/shc/s/p_10153_1...ir+Compressors
probably overkill but looks to be a pretty good buy
Heck! Maybe rethink and get a nice 5gal tank air compressor INSTEAD of the impact wrench. Having a blower nozzle, tire inflation, other air tools is really a quantum leap in garage equipment. Blower nozzle alone dries, cleans, dusts. Just an idea. I'm home alone and bored.
You're right. I should stay away from PEP boys and being tempted to buy things I don't need. Maybe I'll just pick up a little compressor, then I've got everything I need.
Small compressor is the way to go. I use mine to keep tires inflated, blow off water after washing, blow out the garage, run small air tools, etc. Couldn't get along without it.
I have one about this size. Plenty of air for everything except when I blow out the irrigation system for winter months. Then it runs constantly to keep up. Also for sand blasting it's minimal size. Other than that it could be smaller. BTW, I got a mess of air tools for dirt cheap one or two times during a sale at auto supply store. Hold out for the bargains; eventually you'll have impact wrench, grinder, ratchet, air hammer, darn cheap all Chinese made and at least good household quality.
I would recommend Sears for an excellent selection of tools. Most salespeople are fairly knowledgable.
Don't ever stop a Snap-on truck and talk to the owner/driver. If you thought the Porsche was expensive to buy wait till you buy the tool chest
and start to fill it
I use a Dewalt cordless impact wrench. Works great and came with two battery packs and a hard case.
Those look really handy to me. What voltage is yours? Can I assume they have enough juice to remove and install a set of wheels on one battery charge?
BTW, have you used your deionization system yet? I got mine this week, but haven't tried it yet.
I suggest a Makita BTW251 impact wrench. It has 170 ft lbs of torque and the battery life is outstanding using 18 volt Lithium Ion batteries. Very compact and comfortable to use. Will easily remove lugs without the need to use a breaker bar first, as is often the case with lower torque wrenches. Not cheap, but a well built tool.
I believe it is an 18V system which I bought at Home Depot.
It easily removes the lug bolts. Sometimes I turn the gun slowly clockwise to assist in breaking the initial torque. The battery pack probably will take the wheels on and off AT LEAST a half dozen times. I've never run out of juice but I suggest that if you're going away for a multi day event to take an extra battery and the charger. When you put the bolts back on, stop immediately as soon as the bolts tighten and then use a manual tq wrench to finish the job.
I haven't used my deionizer yet....too friggin cold here! But soon!
I have been offroading for over 30 years, and we are constantly airing up and airing down. there is alot of junk out there. Just get a VIAIR 12 v compressor. It will give you years of trouble free performance. The big ones draw more amperage than your cig lighter can handle, so just get a smaller one with a small accumulator tank and air pressure switch if you want a really slick system.
http://www.viaircorp.com/OffRoad/portables.html
