996 twists on a 997.2?
There's a set of turbo twists for sale. Probably my favorite 911 wheel. Will these work on a 997.2? Any thoughts if they'll look too small? Better yet, any pics?
Specs:
7 x 17, offset ET 55, Part # 996 362 124 00
9 x 17, offset ET 55, Part # 996 362 128 00
Specs:
Those my be from a 993, or non-tubo 996. Check this site - I think 996 Tubo should be 18s.
2nd wheel: http://www.wheelenhancement.com/index.php?t=Wheels
Team Owner
I don't think those are the turbo twists you're thinking of--I'm betting that they are this wheel:
The 18" turbo twist is this wheel, which I suspect is what you're looking for:
I use a set of 17" 996 wheels on my 997.1 C2 (nonS) with snow tires as my current winter setup (got a great deal from a fellow rennlister). The wheels clear the brakes just fine and offsets are not an issue, they work just fine on a base 997. The S brakes are bigger so that's a different story.
