Anyone using cheap tires?
Can the folks "poo-pooing" Kumhos and Hankooks explain their reasoning? Hankook and Kumho make excellent tires and their DOT R-Compounds are among the best. Kumho V710s were the fastest for years until the Hoosier A6 came around.
I think a lot of this ends up as brand snobbery vs. actual results.
With that said, the Yokohamas are an excellent tire and have a fairly decent lifespan on them.
However, look at any of the reviews of the Hankook V12 Evo and you will see that they are a faster tire than the Michelin PS2 and second only to the Direzza Star Specs. With the RE11s I imagine this has changed but despite this they're probably still better than most of the stuff on TireRack's site.
I have to agree with edgy. putting inferior tires on your 997 makes just as little sense as putting extremely expensive tires on your volkswagen. I think that a balance needs to be struck between the components you are using. If you plan to just sedately tool around town, any tire will do, but I couldn't see spending all the money for a high performance car if I were going to put inferior tires on it to save a little money. I havent had any problems with my michelins, except for one flat tire from a screw which I drove over. My extended tire warranty got me a free new tire. so I definitely agree with atr911 on this.
I have about 1000 miles on Hankook's rear only (still working down the PS2 on the fronts). However these are off for winter and won't go back on until late April - so I can't give you more feedback than 1000 miles worth for some time (probably end of summer when all 4 tires should be due for replacement).
I use Nittos on the track on 18 inch wheels, but this year plan to try Toyo R888s on 19 inch. So the track is where my most aggressive and spirited driving occurs. Thus my street set get a lot of miles (about 1500-2000 per month) of commuting and interstate driving. Nowhere near the car's limits or any boy racing.
With that in mind, I have been happy so far with the Hankooks. They mounted and balanced without issues, run quietly and have shown little wear so far. Their wet performance has been quite good and they are just fine in the dry for my use. I have seen no mfgr defects or quality issues (such as delam mentioned above in this thread). If things continue as they are now, I will replace all 4 when due with Hankooks all around and use the savings for another set of track or snow tires.
YMMV - this is just a report on two tires out of however many thousands they've sold.
Poseur
Stupid question: can I use a different brand of tire on the rear than on the front? Currently my car has the P-Zeroes it came with when I bought it (used), the rears have about 50% left and the fronts are like new. So I'll need to change out the rears first. I'd like to get away from the P-Zeroes but don't want to change all four. Note: I don't care about performance driving, I drive 15 miles/day to and from work in the suburbs on flat straight roads @ 30-50mph. Once in a blue moon I might take it on the freeway for a short hop, but not more than 70-80mph.
I would never (except in an emergency for very short miles) put mis-matched tires (size, brand, anything) on the same "axle" of any car.
However I don't see a problem with different front/rear pairs as long as you are careful and mindful of what you're doing. I currently use (summer) Hankook on the rear and PS2 on the front. It is just fine. If my car wore tires at the same rate, I would have 4 Hankooks on now just to try them out. But it doesn't, and I didn't want to spring for rear PS2s (and have the tread depth mis-matched front to rear - Oh! My!), so I took the risk/chance/whatever and put the H's on the rear with the PS2s on the front.
I'm not recommending anyone else do this, just reporting that in my case it seems to be working out fine.
My 2010 S came with Bridgestone RE050A N1 (notice the N1 rating). It is a great tire and its price is reasonable.
Sorry Edgy, I have to disagree with you on this. But before I do let me state for the record that all tire manufacturers agree with you and want to see 4 tires of the same type (not just brand) on the car.
Team Owner
Here's a link to the test in question. I think people are making assumptions about the Hankooks:
http://www.caranddriver.com/reviews/...12_evo_page_10
FWIW, I stuck Hankook Icebears on my 996 C4 for the winter and couldn't be happier.
Dan is right and you are very wrong. 2 different tire brands have different grip and compound characteristics. It is courting disaster to mix tire types from the same manufacturer and pure folly from different manufacturers. PAG tunes the chassis suspension for specific tires for a reason...
IMO some of this is nannying, some is lawyers, some is marketing, and some is fact. For me and in my driving style and conditions and on my car, it seems to be just fine. That is the extent of any claim or statement I'm making and I am not encouraging others - just reporting my own limited experience.
I was thinking Dan was being facetious, but in case not I certainly don't see an issue with different brand tires on front and rear. Most folks replace their fronts much less frequently than there rears. When that happens, the difference in tread on even identical brand tires is significant at certain intervals. Why would it matter if you had Michelins on the back and Bridgestones on the front?
By "courting disaster" I presume you mean that either the fronts or the rears will lose traction, in near-the-limit circumstances, before the other end. In other words, the car will either oversteer more or understeer more. This is likely true - but I drive on the street so far within the limits of the car (and my own) capability that it simply isn't an issue for me. If I was pushing the car harder on the street, which I certainly do not recommend given the quality of drivers around me, I would not consider the front/rear mis-match.
On the street I prefer safety to thrills.
Hankooks are so much cheaper that I just cannot understand why you didn't do the fronts too!
