When to change air filter/pollen filter?
When do you guys typically change Air and Pollen filters? stick to Porsche's recommendations or earlier?
What I do? In the Spring or whenever I really get into detailing the car I yank the filter and carefully blow it off with compressed air then put it back in. Never actually replaced one. Gee. Maybe I should replace it, huh?
Clogged Air Filter definitely affects performance. Not sure if blowing air can determine how much filteration is affected. I might inspect this spring and change if too dirty.
Poseur
As with many things, the determination is "it depends." If you live in a sheltered area you can go longer. If you're out here in the midst of ash-fall (like I am) you need to probably do it every 12-18 months.
Poseur
Dan it's just a pollen filter. Blow followed by careful inspection. OTOH, never do it with an engine air filter.
Good point though about cost and convenience! We should all probably just buy a couple next time at the dealer. Then when you find yourself messing with it you have one to reinstall.
trunk, under passenger side plastic panel next to the battery, almost under windshield. you`ll need to unscrew plastic arm that holds it in place and to push that filter in carefully may require some effort. but it is simple enough.
For those with 997.2:
Air Filter Kit $ 58.95
Replacement filters (includes the left and right cone filter) for 2009+ Carrera or Carrera S models.
Filters are Genuine Porsche Parts.
