Skiipping gears
Old 01-14-2010, 06:40 PM
Deansdream
Deansdream's Avatar
Default Skiipping gears
Given enough braking to avoid redlining, any harm done, say downshifting directly from 5th to 3rd, skipping 4th? Or should one always go through all the gears?
Old 01-14-2010, 07:07 PM
LlBr
LlBr's Avatar
AFAIK, Hopefully you are using only your brakes to slow down and downshifting to the proper gear not to slow down but rather only to resume most efficient power transfer to the road. Proper gear depends on what you want to do acceleration wise. Engine probably has enough torque to handle it no matter which gear. Anybody: please correct me if I'm wrong. Racing or beating the sht outta the car is another story.
Old 01-14-2010, 07:47 PM
Edgy01
Poseur
Edgy01's Avatar
It's certainly fine to skip gears up or down, the issue is whether you are skilled enough with the feel necessary to skip a gear and still get a good shift.
Old 01-14-2010, 08:19 PM
John NY-Naples
John NY-Naples's Avatar
When I attended the PSDS two day course, the instructors suggested that there is no need or reason to down shift for engine braking. They reasoned that the brakes on these cars, and for that matter most modern cars, are very good, and there is no reason to engine brake. Engine braking was necessary way back when, when brakes weren't very good. Having said all this, if you down shift for reasons other than engine braking, you can ignore this.
Old 01-14-2010, 08:31 PM
LlBr
LlBr's Avatar
Thanks for the confirmation. Sounds good to me.
Old 01-14-2010, 08:52 PM
At Law
At Law's Avatar
This is true. It is pretty easy skipping gears smoothly
on the way down. However, skipping gears while upshifting
takes a little skill--to do it right that is.
Now, can you upshift smoothly without using the clutch?
Old 01-14-2010, 08:54 PM
russo
russo's Avatar
A known attribute of Porsche is their brakes; hence, shifting down to brake is not the optimal method to slow down.
Old 01-14-2010, 09:02 PM
ADias
ADias's Avatar
Originally Posted by At Law
... Now, can you upshift smoothly without using the clutch?
Please post your VIN so that we can advise people to pass when you sell it.
huntflyer (09-14-2022)
Old 01-14-2010, 09:17 PM
Sadiq
Sadiq's Avatar
OP is not asking about engine braking.
Old 01-14-2010, 09:49 PM
At Law
At Law's Avatar
I don't do it on the 997. I just toy with it on the Jeep Wrangler.
Old 01-14-2010, 10:05 PM
LlBr
LlBr's Avatar
Adding some humor and with absolutely no disrespect to the OP (who's apparently not even talking about engine braking). My former brother in law used to downshift the [expletive] out of his car to slow it down. It was so ridiculous! Like he thought he was a race car driver or something. Now? He's unempolyed, homeless, divorced, and alcoholic.
Old 01-14-2010, 10:09 PM
Edgy01
Poseur
Edgy01's Avatar
Ys, you absolutely can shift gears without the clutch--in an emergency. It just takes some skill and sensitivity to sounds and feelings, to match engine and tranny speeds.
Old 01-14-2010, 10:51 PM
yemenmocha
yemenmocha's Avatar
I only skip gears when upshifting sometimes due to a difficulty in merging with traffic. 1st through 3rd gears are going nicely then realize I have to mellow out to merge, so I'll go from 3rd to 5th. There's no real danger of hitting the wrong gear in this case.
But I fear that someone going from 5th to 3rd could accidentally hit 1st, so I don't think it's a wise idea. Heck I'll usually go 6th to 5th then 4th so I don't hit 2nd by mistake on the freeway.
Old 01-14-2010, 10:58 PM
sharmat
sharmat's Avatar
Its so easy to skip 1st going down hill (as in a long drive way). I can easily go right to 2nd.
I do 6- to 4 often as long as the speed is low enough and not for "engine braking"
Also 1st is hard to engage anyway if you are going too fast so i dont worry about accidentally getting into 1st.
Old 01-14-2010, 11:49 PM
simsgw
simsgw's Avatar
It's not as tough as it sounds, given that skill and sensitivity. No worse than double clutching a crash box really. However, I wouldn't want to do it regularly on a car I cherished. I've only done it when the clutch master cylinder has failed on a car. Mind you, I haven't had that happen for thirty years or so...
Gary
Quick Reply: Skiipping gears
