PDK shift knob removal
PDK shift **** removal
Any one pull the PDK shift **** off?
I need some instruction on its removal.
For manual ***** the trim holding down the leather boot just prys straight up and unsnaps.
Lifting up the leather you can see if your **** has a set screw under there.
Others have no set screw and just require semi-gorilla strength to turn pull up and off.
Again: that's the manual **** situation. FWIW.
click on PDF at bottom of this link:
http://www.bmracing.com/PRODUCTS/Por...-Sport-Shifter
