PCM 3 - iPhone/iPod interface quirks
In my 997.2 S I have both Bluetooth and the iPod Audio Interface.
My iPhone works fine with Bluetooth. My iPod or iPhone work fine via the iPod interface (using the new Y-cable which requires both the iPod and USB connectors plugged-in to charge the device).
However, when the iPhone is connected through the iPod connector it ceases to work via bluetooth (going into airport mode) and says so on a warning message. I find that odd, as one can use an iPhone to play music while the phone remains active making/taking phone calls. What is your experience with this? Is this also the case on other makes offering Bluetooth and iPod connectivity?
I have a old 3rd Gen iPod that works perfectly with the cable without the USB tang.
I have a 3G iPhone that works great with the bluetooth interface as a phone. I have not tried to use the iPhone for music having read that there are issues, hence I dusted off the very old iPod for music.
Try your iPhone. I bet it will play music through the iPod interface but it will tell you that phone service will be off. My experience is with an iPhone 3GS - I do not know what happens with previous generations.
Anyone tried his iPhone through the iPod connection?
My iPod Photo plays music AND charges via the single-ended iPod DIN to dock interface cable. My phone, in my pocket, works via the Bluetooth interface. It doesn't answer the OP's question, but does say that iPod Photos do work with just the plain jane single ended cable. I have heard that if you have the double ended cable for the newer iPods, but an older iPod that would work find with just the single ended (IEEE1394 charging) cable, it would not work with the new cable... apparently a cable can only be (or the new 2headed was only manufactured to be) used to charge in one fashion - either via FireWire (IEEE1394) 12v line, OR USB 5v line...but not both.
...My iPhone works fine with Bluetooth. My iPod or iPhone work fine via the iPod interface (using the new Y-cable which requires both the iPod and USB connectors plugged-in to charge the device)....What is your experience with this? Is this also the case on other makes offering Bluetooth and iPod connectivity?
I had to go through every ipod I had in the house to find an older one that would actually charge and work w/ the 997.2 ipod adapter, and then keep the iPhone in my pocket for its bluetooth connectivity.
I just received feedback from another person who says that the iPhone does indeed work with the iPod port and bluetooth (phone) if one ignores or cancels the warning to go into airport mode. Interesting!
My 997.2. Hmmm I was very disappointed w/ the ipod interface w/ a brand new car. I dont have a Y cable, just the one that was in the car when I got it 3 weeks ago, that w/ a single plug, plugs into the ipod circular port. It will play music from my iPhone 3G and while plugged in the bluetooth works fine. However, it doesn't charge it. Does your Y connector charge your iPhone? Is this something new'ish I could get from the dealer?
With either cable the iPhone will throw a blue window warning suggesting to switch to airport mode. Ignore the warning or cancel and it will work fine in both iPode mode and phone connectivity via bluetooth.
I think this answers the issue I raised. Thanks to all and in particular to Howie on 6speedonline who posted the definitive reply.
So that whole airport mode issue seems to be purely an iPhone problem... the iPhone trying to switch modes based on what it thinks is the most common situation... I guess iPhone users cannot reconfigure when that window comes up (if at all).
I got a dedicated iPhone connector from Suncoast and it works seamlessly w/ my iPhone: plays music, charges and I can use the PCM interface to scroll thru various playlists and tracks. The iPod interconnect that came w/ my car only works with my iPod classic, ie when I connected my iPhone, my iPhone wouldnt charge, or freeze or not play music intermittently. So, I suggest you purchase a dedicated iPhone or iPod connector depending on what you are using. -Jay
Beg your pardon.... trying to multi-task at work and failing miserably. I do get the airport mode warning when I connect in my BMW as well as Lexus. I ignore the warning and the thing works like charm in my 911, lexus and bmw. I hope I now answered the actual question you were asking. -Jay
Basic Sponsor
There is a software update for the PCM.....email me and I'll go into detail on what you can read off of it now to determine if you need the update. Had it done today, about 20 minutes.
eric@bumperplugs.com
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring
2009 997 Turbo Cab
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
