997S as track car may suck
#31
Is PSM independently fused in the 997.2? I'm familiar with some other marques where the standard procedure for fully disabling PSM is to pull the ABS fuse. Perhaps a similar approach is possible with the Porsche.
Sorry to hear about the quirk, I'm sure it's tremendously frustrating.
#32
https://rennlist.com/forums/search.php?searchid=4721365
#33
I bought my 997s for driving and as a track car so I could sell the race car, truck, and trailer and just do DE.
I am now having second thoughts
Two other 997 at the Daytona DE had problems with the PSM not working onthe high banking. Not good!
My 997S at Roebling road and it makes a rear shake as I exit turn two. Not all the time, but it means I do not get on the gas as I used to. Blamed on the PSM again.
I tried no PASM, PASM on, shocks on only, all combinations and still it would let me down out of that corner.
I am thinking that this new technology is not good for DE cars.
Others have reported that they replaced all this PASM with aftermarket so as to be able to race the cars.
Anyone want to trade a GT3 for a nice 997S 2006??/
He knows the Roebling track. His explantion is I am on the throttle early and the car is not spinning the tires but making the tires hop due to rapid throttle input. Then the PSM kicks in to try and stop this nonsense. this gives the wiggle I had. His solution is to turn off the PSM while on the tack, but leave Sport on. Also I might have to hestitate getting on the throttle. He said the PSM will still come on if you really get stupid and get the car really out of sorts.
This is the best answer I have heard so far.
#34
#36
Andrew,,i did notice that your butt was twitching a lot on turn 17 sebring last month when i was following you....dont know if it was the bumps or bushing issue..have you checked yours...?
#38
Stupid question, by PSM failure, do you guys mean that PSM kicks in? by applying ABS to sort out the car?
#39
Hint: the 'S' in one of them stands for 'suspension' and in the other it stands for 'stability'. What you describe sounds like an intervention to maintain stability. The only way I know of to induce that with PSM set to 'off' is when both front wheels enter the ABS range. That seems unlikely leaving a corner so it doesn't sound like vehicle error.
By the way, did you know the GT3 has PSM as well?
#40
Neither the problem the OP described nor MDrums's issue sound like a failure at all. I'm not clear why PSM is on at all if we're talking about an experienced driver on a track, but each to his own. But assuming it is on, where is the failure? And who decided it was PSM and not something else? The bushing problem adfsouth describes seems a much more likely cause for such behavior.
Furthermore, we don't take race cars onto banking without modifying the suspension specifically for the track we're visiting. I appreciate you'd like a universal car, but no one makes one. A superb road and track car does not mean one that goes anywhere and does anything. Our full race cars do not, so why should we expect that of a car that has to throw civil road behavior into the design?
I don't mean to be unsympathetic, but damn it, the Carrera S is a road car that loves going on tracks. Not a race car with fenders and street legal lights. If you want to run the banking at Daytona to have fun for an afternoon, that's fine. I'd like to myself if I didn't live on the wrong coast. But if you want to race at Daytona, then get a race set-up on your suspension. Remove all the road bushings and replace them with steel, change the springs, put in a roll bar and... oh, I remembered a short cut: buy a GT3 Cup.
Gary, a bit grumpy tonight, but glad he
isn't driving a race car to a wine tasting
#41
Quote:
Originally Posted by mdrums
Please re-read my post...turning PSM off does not help and still tiggers PSM failure. Unfortunantly PSM either on or off is always lurking in the background.
No, you did not say that. You said you've tried it with PASM on and off, not PSM. You do know the difference, don't you? I wondered when I saw your original post because my PASM has no on/off. It only has normal and sport settings, but I figured your older model might be different.
My mistake,
Gary
#42
#43
#45
My suggestion is to call Porsche Motorsports in California and see if they have any suggestions. Good luck.
