Rear spoiler creaking on lift
I heard this noise once when I first got my car many years ago. I have never heard the noise again. The solution was very simple. I never again pressed the spoiler button while the engine was not running. Actually I don't think I've ever pressed that button with the engine running either.
While WD-40 is a good quick fix for many things and probably provides a quick fix here as well, it is a very thin lubricant and mostly evaporates. I would not recommend it as a long-term solution.
pongobaz's recommendation of white lithium grease is probably best. It will hold up for a very long time and provide the best possible protection against wearing out the gear teeth. You don't want to risk having to replace the gear mechanism later.
