V1 Hardwire/New Radio/iPod connector/ Brake Pads
I hard wired my V1 today into the self dimming mirror per the instructions I found here on the board. It was fairly frustrating as it took a ton of courage to get the damn interior light out. What a tight fit! I was sure I was going to break something. I followed the instructions but used wire taps to connect to the ground and switched hot. Tried the wrong wires first, tan, brown, sheesh so I eventually had to get a magnifying glass and read the numbers on the plug to find the hot and ground. Of course when confirming for power in the plug with my electrical tester, I caused a spark and then blew the fuse. Replacing the fuse got me confirmation of the hot and ground but still no juice to the V1. Crap. After checking every connection I finally cut the phone plug and reversed the polarity and YAY it works.
On my car anyway, the red is hot and the green is ground on the modular plug, opposite of the directions I found here.
https://rennlist.com/forums/997-foru...the-997-a.html
However, if it wasn't for these directions I wouldn't have been able to do it anyway, so THANKS to 1080i Addict. I also finally received my new PCM and now it all works just fine. As an aside, my iPod wasn't charging UNTIL I plugged the USB connector into the car as well as the iPod connector. I wasn't aware I had to do both. At 2010 miles I have used about 2 quarts of oil and the car is wicked fast.............I am saving for tires and need to replace the stock brake pads with low dusters, anybody have a good experience with low dust aftermarket pads?
Todd.....when I plug my Ipod in with the cord that comes with the car I get the message on the Ipod that says it is not being charged...I was unaware that you could plug in a USB cord and get the Ipod to charge. So I assume you plug in the male USB to the car input jack but where do you plug the opposite end ? Thanks
The new wire will have 1 end for your phone. The other end will have the S-video looking plug, and a USB plug attached to it. Use the S-Video for data from you phone, and plug in the USB for power.
You can now get this updated wire from you Porsche parts counter.
Dr. Z, my cord has one plug for my iPod and then it Siamese's into a USB and then the S video plug end, like AngMO18 has said. So I plug it all in and I get charged. Adias, I dont think ceramic pads or what I used to use, DS11's (for the track) sacrifice safety or performance, sometimes aftermarket pads enhance performance. I was looking for other owners with experience in these matters. I have Rejexed my wheels and they are easy to wash but washing wheels every two days is not fun for me. I don't have any experience with the Swiffer Duster, Thanks I will check it out.
No pad recommendation. I painted my wheels a dark grey... so its not so much an issue for me. Not the cheapest solution, but the look works well and has that side effect of hiding brake dust.
Todd,
I am considering hardwiring my V1 but have been a little chicken to pull the trigger. Any tips on getting the light assembly out? I'm also curious what kind of wire taps you used and where you got them. Thanks.
Based on Adias' prior recommendation, I've taken to using a Swiffer on my wheels every few days. It works well. Only problem is that my wife has suggested I learn how to use the Swiffer inside the house!
At least on my car, there is a tiny little accent light that shines down from the RVM mount. I just took that light out, snipped the wires, and hardwired my Passport to that. Works great!
The proper wire did not start coming with the vehicle until late 09's. Apple changed the charging ports on their new phones/ipod to help prevent people from buying non-apple accesories.
I ordered the plug anyway and will just plug it in for an hour about once per week when it needs to charge. I will also stop by the local Apple Store and ask about this problem.
Any advice from Apple techs would be appreciated.
T Silnner
