resetting Moonroof for "one click close"
I just did the reset process as well and it didn't change anything.
You need a smart top to be able to do this. It is a rather expensive add-on for a feature that should have been programmed into the existing electronics.
This also gets remote open. A really nice feature to let all the heat out of the car as you walk up to it.
Paul
Paul
997.2 Reset process in case anyone is looking...
...what works in my car:
1 - close the sliding roof
2 - hold the forward/close button (referred to as Rocker Switch B in the manual) for several seconds / don't release it
3 - the sliding roof will go through an opening / closing / sliding sequence that ends with it closed.
2009 C2S 174K miles
Good information. Thanx!
Two questions:
1) Why is a reset necessary?
2) If one-button auto-close is a regional thing, then I should be able to set this via my Durametric.... anyone know where this feature resides in software?
Peace
Bruce in Philly (now Atlanta)
Two questions:
Peace
