TPMS gone haywire
Old Aug 16, 2009 | 09:06 PM
roadrat's Avatar
roadrat
Default TPMS gone haywire
TPS says flat tyre or low pressure. reset it several times, adjusted tire pressure, reset, etc etc.
still going crazy.
any ideas?
Old Aug 16, 2009 | 09:12 PM
cole328's Avatar
cole328
Have you doublechecked the ?summer / winter and "load" settings?
Old Aug 16, 2009 | 09:18 PM
roadrat's Avatar
roadrat
i changed the load settings to see if that was the problem, but still having a problem.
i'm in TX, so its 365 summer
Old Aug 16, 2009 | 09:28 PM
cole328's Avatar
cole328
Hmm...sorry then, as that's all I could think of. Sounds like a quick trip to the dealer is in order.
Old Aug 16, 2009 | 11:47 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Year of car? Battery low in sender?
Old Aug 17, 2009 | 08:36 AM
roadrat's Avatar
roadrat
2007. anyway to check battery in sender?
Old Aug 17, 2009 | 03:29 PM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Batteries should last several years. (My 06 has TPMS and no problems yet).
I can't imagine a way to test the batteries separately. These are sealed toss-away units. Try substituting another set of TPMS-equipped wheels to see if the problem goes away. If it does,--it's the senders.
If not, try troubleshooting the other end. Change wheel dimensions and then back again. Then road test it for a few miles for it to register the newer settings.
