100cell - 200cell cat question + advice
I don't post here often as I am a 993 guy but a friend of mine asked if I could do it for him so here is the question.
He would like to have a more pronounced / porsche sound like my 993 has.
The 993 is a 3.8 with cat bypass and motorsound mufflers.
His car is a 2008 carrera S. So far he put a cargraphic cross pipe (X-pipe?) and a K&N airfilter.
Is replacing the cat's with 100 or 200 cell a good idea or maybe you guys have better advice?
Thanks in advance!
Thanks in advance!
I had A.W.E. 200 cell (HJS) cats on my 06S and I thought it sounded great and that was with stock muffs! Probably sound even better with Cargraphic X-pipe and he'll get a few hp as well.
I currently run the AWE 200cpi metallic cats, if I had to do it all over again though I would run the 100 cpi cats. You can go over to FVD and they have a 02 sensor extension that will make the computer less sensitive to the 100cpi cats. The 100cpi cats doesn:t mess up the computer, what it does is the signal will be to hot and kick off a CEL. Even this may not happen, but if it did there is fixes available.
Softronics software also makes the tolerances higher for the 02 sensors so you can run 100cpi cats or no cats if you so desire.
Dave
Dave
So 200 cell should be the best solution?
Any idea if the sound difference between the stock cats and the 200 cell cats is really noticable?
The cats are 45-50% of the sound deadning. If he does the 200 cpi cats the car will sound much more aggressive, it still won:t sound like an air cooled car though. It will sound like a pancake 6 but not like the air cooled cars.
If he wants to build a custom cat setup using 100cpi cats it can be done quite a bit cheaper than a ready made cat setup ala AWE/Fabspeed, which both use the HJS cat. Either way he can:t go wrong with the AWE setup.
Dave
The plan is to cut the original cats open and replace the cats with 100 or 200 cell's.
if I understand correctly, with 100cell cats i need to updat the motormanagment?
Is the difference between 100 or 200 really that noticable?
Dave
