Battery Replacement - Public Service Announcement
Old 04-13-2010, 05:28 PM
  #31
Minok
Minok's Avatar
Originally Posted by quickxotica
In normal stop-start driving it is fine as long as your alternator works... although I admit it is comforting to have the H7 waiting in the wings just in case.
If your alternator doesn't work right, no battery is going to be useful as you will discharge your battery to dead pretty quick in a single drive or a few starts.
Old 04-13-2010, 06:50 PM
  #32
quickxotica
quickxotica's Avatar
Ha! That's true. Sorry for being nonsensical... it's a habit of mine.
Old 04-14-2010, 05:51 PM
  #33
dallison28
dallison28's Avatar
Originally Posted by 478100
If you sneek into Wal-mart, you can buy a 1000 CCA Exide (WM calls it something else) battery with vent and a 3 year warranty for $78. Yes, you have to use the outer most battery clamp hole and supply a bolt but no biggie, took me less than 10 minutes to install. Trust me, I'm no mechanic, but wasn't about give anyone a couple hundred bucks + to supply and install a battery.
and a 3 yr free replacement. after all there are only a few battery manufacturers in the US.
Old 04-14-2010, 09:06 PM
  #34
ohsixx
ohsixx's Avatar
Thank you. I had long ago made myself a note on the MTP-91 as the best replacement battery. I have now changed that to the MTP-H7.
Old 04-15-2010, 12:38 AM
  #35
TigerStadt
TigerStadt's Avatar
Went with Interstate also. Easy install.
Old 04-15-2010, 02:34 AM
  #36
Jay Jones
Jay Jones's Avatar
I picked up a Interstate MTP-H7 yesterday and dropped it in my 2006 C2S. Installation was a piece of cake, a very easy do it yourself task. I figured it was good insurance against being stranded somewhere. Big thanks to the OP for starting this thread, it motivated me to get this handled!
Jay
Murph49 (09-09-2020)
Old 04-16-2010, 04:18 PM
  #37
Mineral
Mineral's Avatar
Must be something in the air affecting Porsche batteries. I also replaced mine yesterday after it turned up dead after 3 weeks on a trickle charger. I used the Interstate MTP-H7 on advice in this thread. Can re-reconfirm it's a perfect fit - vent tube and all. Paid $136. Ten minute install.
Old 04-16-2010, 04:41 PM
  #38
Minok
Minok's Avatar
How old was the battery you replaced? I'd be concerned about the utility of the trickle charger if it cannot keep a sub-5 year battery in shape.
Old 04-18-2010, 04:27 PM
  #39
Mineral
Mineral's Avatar
My relpaced battery was 5+ years old (original in the 2006 car), and so ready to go. I've used the trickle charger most of the time when car sits for over a week, and am happy with the results using it.
Old 04-18-2010, 06:11 PM
  #40
utkinpol
utkinpol's Avatar
if anybody has a free second - could you take your multimeter and measure voltage in the cigarette lighter socket when car runs at idle and when at 3K rpm, please.
Old 04-18-2010, 09:01 PM
  #41
Fin Fever
Fin Fever's Avatar
interesting question, and an easy one for me to check, cause my escort radar detector is set up to default the screen to the cars electrical system's current voltage.
engine off 12.7 V (after sitting for 5 hours in the garage )
engine at idle (990 rpm) 14.7 V
2000 rpm 14.7 V
3000 rpm 14.7 V
4000 rpm 14.9 V
I ran the test with the garage door closed, now I have a headache, I am going to go take a nap.
Old 08-14-2010, 07:38 PM
  #42
sbkim
sbkim's Avatar
Originally Posted by JasonKM
buy a 94R battery (same as Interstate H7), which is a direct fit replacement. Aftermarket sources list a group 49 battery that is longer requires you to play around with the clamp bolt. 94R is a common battery for Mercedes and Audi cars and even some Chrysler vehicles during Mercedes ownership.
Has anyone tried 94R? I noticed that 49 won't work not without modifying the location of the mount. Thanks!
Old 08-14-2010, 11:20 PM
  #43
MattAu
MattAu's Avatar
I bought an Energizer 108-94R from Walmart and it was a direct fit on my 2006 997 S cab. It took less than 5 mins to swap the Porsche one with the Energizer one. The Energizer is made by Johnsons Controls INc.
Old 08-15-2010, 12:11 AM
  #44
sbkim
sbkim's Avatar
Thanks Matt - just picked one up this evening.
Old 08-15-2010, 10:38 AM
  #45
sbkim
sbkim's Avatar
Special thanks to JasonKM for making this easy. As per his advice, I installed Walmart's EverStart MAXX 94R. It fits absolutely perfectly! It's almost identical to OEM battery except this carries 765 CCA and 3 yr direct replacement + 9 yr pro rate. I paid $77 + core charge which seems like a bargain compare to OEM. This battery was made by Johnson Controls.
Quick Reply: Battery Replacement - Public Service Announcement
