First DE Help
From my reading of the requirements, I need a fire extinguisher and a helmet. So I am asking for recommendations here.
I have a 2007 997-S with Adaptive Sport Seats. I have done a lot of searching here and googling and havent come up with any leads other than SpeedTactics offering and the OEM part for sale from Suncoast. I reached out to suncoast for info on installing the OEM part and have not had a response. So what do you guys reccomend for FE and how hard is it for a non-mechanical guy to install?
Also I read that it is important to try on helmets (both on your head and in the car) so its best to shop locally... and I will follow that advice.. but what models are people wearing for drivers ed? full face?
THanks in advance for reading and responding.
BEst,
JJMc
For helmets, you definitley need to try them on. Needs to be snug but comfortable. You don't want your head rattling around in there if there is an impact. I bought a G-force Pro Force full face helmet about $250.00. Bell makes one about the same price. I think for DEs, these helmets are fine. For racing I would buy a nicer helmet. I'm sure someone will chime in here and explain if the more expensive helmets offer more protection. I would never go on a track without at least a full face helmet. I'm sure your chapter requires a helmet snell rated SA2005. There is alot of info at the snell website about what the rating is. Hope this helps
The fire extinguisher bracket I used was the Brey-Krause with quick disconnect. It's functional and looks nice in the car.
Have fun.
BEst,
JJMc
Try a DE with Schattenbaum or jersey shore or NNJ region and save on the FE till you have a few DE's under your belt.
If you think you'll continue to do DE or autoX, then by all means by yourself a good helmet. If you think this may be a one time thing, see if you can find a friend and borrow a helmet that fits for the event.
Read about the line on the track that you are going to DE. There are usually written descriptions giving a turn by turn explanation. Also, check out YouTube with search terms like PCA to see if you can find some 997s on your track. This can be a good way to learn the line assuming the vid is from a capable driver. Also look at www.trackpedia.com which is a great resource for links.
Go in open-minded and humble and you'll do well. ALWAYS be open to instruction: I have yet to meet a 'bad' PCA instructor.
After you get hooked, sign up for PSDS (perferably the two-day course) and watch your driving bump up several notches!
Most of all, HAVE FUN!
Otherwise, the Suncoast unit is pretty easy to install. Unbolt the seat, tilt it up, bolt in the OEM FE mount, re-bolt the seat. I moved one from car to car, but had the dealer do it as part of the trade (he didn't charge me, but said it was very easy). By the way, the "metal on metal" requirement for FE in PCA events is met by the OEM unit. There is some high density plastic in the frame, but the bolting piece is metal on metal. I had mine checked and approved.
Other than that, just pay attention and have a ball...you are not going to believe how these things perform on the track. it is not even comprehensible what it can do, and street driving gives you no inkling.
(contemplating on whether gas bag is one or two words)
We still have room for the August 26,27 event at NJ Motorsports Park. Nice new facility.Love to have ya.
