Tire pressure for 18's on 997.2
Old 06-18-2009, 12:28 PM
jk335
jk335's Avatar
Default Tire pressure for 18's on 997.2
Hi Guys,
Took a little break from the forum to go out and starting putting a few miles on the new car.
I am currently riding on 36/ 44. What do people recommend for stock 18's on the 09 911?
Thanks!
Old 06-18-2009, 01:19 PM
gray911
gray911's Avatar
Recommended is 34/39 under partial load. 36/44 to bouncy under partial load, ok if full capacity.
Old 06-18-2009, 02:12 PM
civerson4
civerson4's Avatar
The dealer set our car at 36/44 when we picked it up.....ride was OK--but the TPMS said the pressures were +7 on the rears. I read the manual and what gray911 says is correct--34/39 for partial load. That is what we have it set for now and all is well.
Old 06-18-2009, 02:55 PM
todd.
todd.'s Avatar
I always go +2 on all my cars.
Old 06-18-2009, 03:48 PM
jk335
jk335's Avatar
thanks guys. I'll look into the 34/39. great to see the board booming!
Old 06-18-2009, 08:23 PM
RonCT
Moderator
RonCT's Avatar
Welcome back and glad to hear you are enjoying your new ride! For the others, just something I've noticed... The TPMS in the 09 is dead-on accurate and fast. When it says 33/39 on my 19s, it really is 33/39. Of course temperature will change PSI, so I don't sweat it when the numbers are high or low cold. For example (I'm making up the numbers), if I set to 33/39 at 70 degrees, it might read 1-2 PSI low if it's only 60, or 1-2 high if it's 80. So, I guess set and forget at whatever your "average" temperature is.
Our roads here in CT are rough enough, so I always shoot for the recommended light-load cold pressures.
Quick Reply: Tire pressure for 18's on 997.2
