Second cooked 997.1 PSE, looking for alternatives
My '07 C2S was originally equipped with the stock exhaust. I wasn't unhappy with the exhaust, but when another member here mentioned that they had a brand new PSE laying around that they weren't going to use I grabbed the opportunity and bought it for my car. I did the install myself, not bothering to hook up any of the vacuum tubing (as others have done) and was quite happy with the sound of the "hacked" PSE. They really do sound great.
After a year or so the exhaust developed a loud buzzing rattle, worse when the car was cold, and I took the car in to my OPC. Surprisingly, they replaced the PSE under warranty (above and beyond the call, given that it was obviously not factory-installed). They said the inside of the exhaust resonator was "a mess." They didn't hook up any of the plumbing or relay or anything either when they replaced the resonator.
That was a year ago, and to my chagrin the replacement PSE has now started with the same buzzing. Aggressive throttle (rapid increase in RPM) induces a loud and embarrassing buzzing. If I'm light on the throttle it's almost imperceptible.
I have no clue why I've had such bad luck with the PSE. Obviously plenty of people hack their PSE and never have a problem. Just guessing, I'd point to my track time (couple thousand miles a year) and the consequent time spent at WOT with high exhaust flow going through the resonators. I think I'm just breaking the little baffle flap thing loose from the "abuse." That's total speculation, though.
I doubt I can finagle another warranty repair and I'm disinterested in another PSE for fear that the same problem will just come back in another year. I'm considering going back to the non-PSE exhaust (which, naturally, I didn't keep and would have to buy) or aftermarket.
I'm not concerned about power gains at all and I'm very sensitive to droning (being in a cab). Any advice on which aftermarket options make sense? I just want something that sounds on par with the PSE without being ridiculous or annoying.
For the price you can't beat this hack. I gave away my take-off muffler for someone else to enjoy the sound. I'd be surprised if you couldn't get some donor mufflers from somebody here.
The symptoms you describe are spot on with the symptoms I had until they replaced the PSE in its entirety.
Nugget,
This has happened to me as well. I unplugged it for a while, did some track time and presto, dead resonator. The dealer said that the welds on the first year 2005 were not as good and the 2006 and beyond (which is what the car has now) will last. Obviously not as many of us are having the problem.
Personally - On my 993 I had a Fister type set up and coupled with the classic air-cooled sound it was glorious.
Thinking of going X-51 header with FisterD exhausts, leaving the cats and resonators (first mufflers) on any thoughts?
Has anyone run this?
