Question regarding lights...
Old May 21, 2009 | 12:58 AM
rijowysock's Avatar
rijowysock
Question Question regarding lights...
couple questions here, thank you for your help.. the first one might seem simple but i really would rather ask then try and have battery die...
in this gentlemans pic i see his lights are left in "home"... if i leave my lights there i can lock the car and they will turn off and not drain anything? can i leave in any other positions without draining the battery?
http://i184.photobucket.com/albums/x...Burkett/P2.jpg
also.. in my sports chrono it says "lights" i can choose DRL (i know what this does) but then says a 0-100% question and a time question.. what lights do the %'s refer to? and what lights does the timer affect?
thank you... i left it on home once... and waited and waited and waited and didnt turn off so i was like hmmm.... hell if i just close doors and leave unlocked the interior lights seem to stay on forever too so i always lock just to be sure... been stuck with dead battery toooo many times to chance it.
-riley
Old May 21, 2009 | 02:09 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Porsche assumes a reasonable amount of driving on these cars. Thus, the battery will be charged up enough to sustain leaving the home lights on for a few minutes. I routinely leave my light switch in that position.
Some of the lights can be adjusted for brightness, e.g., the console light that comes out of the bottom of the rearview mirror. It's a small directional light that can be adjusted by you for how bright it is. I have mine left at the factory default.
The level of sophistication is quite high in these cars with the way lighting is controlled. For example, if you leave your trunk (hood) up or your decklid (engine) up, the light will stay on for about 2 hours. Eventually it will go out.
If you are running into multiple experiences with a dead battery you are among most of today's Porsche owners,--you don't drive it enough. Put down the mouse and go drive.
Old May 21, 2009 | 02:50 AM
rijowysock's Avatar
rijowysock
i drive a lot, put about 1100 miles so far on it since i bought 4/20
im asking if i leave in "home" and lock doors... it stays on a few minutes or till i turn to off?
if i leave on "on"..... it stays on a few minutes or till i turn off?
the % on my sports chrono is for which? and the time on sports chrono is for which?
Old May 21, 2009 | 03:27 AM
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
The car will turn it off within a couple of minutes. There's nothing wrong with leaving it in HOME.
If you go to your owner's manual it will explain which lights are affected by the sports chrono controls.
Old May 21, 2009 | 03:55 AM
rijowysock's Avatar
rijowysock
i did go thru, i looked at like 8 diff lighting sections and then in the PCM book, PCM book was least helpful... just said look at other book regarding the % and time..
ill look again, maybe in a diff section i overlooked...
Old May 21, 2009 | 04:06 AM
brendo's Avatar
brendo
i left mine with pretty much all factory settings and did just fine. home does not drain the battery.
Old May 21, 2009 | 10:29 AM
sharmat's Avatar
sharmat
The controls on the PCM only control the duration and intensity of the interior lights. If that is what you are asking. The home switch only keeps the fog lights for a few min. To my knowledge it does not affect the interior lights at all.
