tire mounting & wheel alignment
Go where-ever you trust.
On mount & spin....if your wheels are expensive, trust & care is important, since the handling, mounting process always has some risk.
A good dealership is usually a safe bet....or a trusted speed shop. I specify flat-Porsche-type weights.....and if they spin up way off to please move the tire on the rim, reinflate, re-spin.
Always request in advance align spec sheet as part of the deal....review it, file it for the next time you have align as point of ref.
Moderator
Always a trusted Porsche race shop. Here in CT we have many to pick from - they all have the right equipment and are used to dealing with high-end wheels, tires, customers, etc. Besides, the rates are much less...
Poseur
Lucky for us more and more people are buying cars with fancy wheels. As a result, many shops you wouldn't have considered 10 years ago do a very good job mounting low profile tires without trashing the rims. I use a local shop for their convenience, and they use the Hunter Douglas dynamic spin balancer to set the weights. For wheel alignment I use my brother in law! I recommend a good alignment just after (or before) a 4-tire replacement,--as a minimum. Try to find a shop that can easily get such a low car onto the alignment rack, and ask them to take care of the rims. They can put a piece of silver duct tape on the rim to protect them from scratches when you mount the thingys they use when doing the alignments.
When I am just getting new tires I often opt for just taking the rims in,--having an extra set of wheels or jack stands comes in handy then, I just don't take chances with the PCCBs with people who won't understand them and avoid the problem in the first place.
