PASM Sport option spring rates
Just got my new 997 C2S with PDK and all performance options. I chose the "PASM Sport Suspension" which is listed as follows:
P17 PASM Sports Suspension Package 950.00
Listed in configurator as:
"Electronically variable active damping system with two manually selectable modes and limited slip rear differential lock. Ride height lowered by 20 mm."
It lowers the car an addition 10mm for a total of 20mm from the stock C2. A main attraction was the limited slip.
This car is a VERY sharp knife - handling is unbelieveable (this is my 4th Porsche).
The ride is also very firm and I'm wondering if anyone knows if the spring ates are different from the regular S springs - in addition to being 10mm shorter.
Newbies Hospitality Director
Check out eh last two paragraphs in the link below concerning PASM Sport suspension.
PASM vs PASM Sport
PASM vs PASM Sport
Front:
• Basic Carrera chassis Spring rate: 27 N/mm
• Carrera/Carrera S PASM chassis Spring rate: 33 N/mm
• Carrera/Carrera S PASM sports chassis Spring rate: 36 N/mm
Rear:
911 Carrera /Carrera S
Basic chassis Manual transmission Spring rate: 43 N/mm
PDK transmission Spring rate: 46 N/mm
PASM chassis Spring rate: 60 N/mm
PASM sports chassis Spring rate: prog. 65/95 N/mm
From the 2009 997 Technical Info Booklet
Rear:
