anti freeze and windows with a mind of their own.
A friend of mine had his 996 C4 cab in for service at a local dealer.
He questioned how often to change/flush anti freeze. They told him they never do unless doing other service work where it is required.
They just top it off if needed. Any thoughts?
He also has a problem wtih his windows. They now go half way down when opening door rather then the 1/4 inch increment . Resetting does not solve the problem. Dealer said they had never seen it before and could not fix it.
He does not post here. Just trying to illicit the help of the experienced hands on
board at Rennlist. thanks in advance for any insight on either issue
I would disagree with the dealer... they absolutely CAN fix it, but their problem is they have no idea what they need to fix. However, they should then get on the ball and do some research or call on Porsche for help. All the bits are there.. its either the window position sensors, part of the motor or something that controls the motor (and of those controlling elements there is a limited list).
