DIY 997 Muffler Install
The following is a DIY Muffler Install for the 997. Very similar to the 996, but details might not be obvious or posted. Here I will key off what is known already about the 996, and will assume reasonable shade tree mechanic ability.
First, I refer to the fine threads:
Removal of the rear bumper cover and muffler:
http://www.renntech.org/forums/index...howtopic=16935
996 sport exhaust and bypass pipe install:
http://www.renntech.org/forums/index......p=6&#entry6
Here are some items to consider and watch out for:
1) Find a safe stable way to jack up the car with fail-safe in case of jack failure.
2) Remove rear wheels - it is alot easier to remove and install the mufflers with them off
3) Remove rear bumper cover - Remove rear tail lights to access a lone hidden torx screw and see 1 torx in wheel well, in addition to the other obvious screws under the engine lid and under the car - it is alot easier to remove and install the mufflers with the cover off
4) Remove heat shields to access the mufflers - see my pics below, the fasteners are very obvious
5) To remove and re-install new mufflers, follow the above threads......
6) I used WD-40 soak on muffler fasteners prior to removal and fused aluminum anti-seize compond to lube up muffler joints for install.
7) I found that a ratchet with a pivoting head and just the socket was more useful and easier than a ratchet a universal joint and extension and socket.
Here are some pictures which may help:
Torx behind tail light for bumper cover removal:
http://img517.imageshack.us/my.php?i...ghtforrwl7.jpg
Torx in wheel well for bumper cover removal:
http://img71.imageshack.us/my.php?im...wellfortp6.jpg
Exhaust shield that needs to be removed:
http://img508.imageshack.us/my.php?i...inplacees0.jpg
Exhaust shield after removal:
http://img71.imageshack.us/my.php?im...mufflercx7.jpg
Hope this is useful
UJ
Hope this is useful
UJ
I've installed dozens of exhausts on the 997 and I never removed the rear bumper.
Just the 3 x M8 nuts on each side that attach the muffler-bracket to the holder and the pipe clamps.
One torx screw on each far/lower side of the bumper to get a bit more clearance when dropping the exhaust.
Gert-
I am referring to the bumper cover, not the bumper - I guessing you are too.
I dont have access to a lift, so I removed those extraneous pieces so I could see better and have slightly more room to wrench- it helped me - I am just a novice.
As you likely know very well, the cover comes off in about 5 minutes max, if you are quick with a screwdriver. I took advantage of the cover removal and cleaned those previously unaccessable areas.
Thanks for your comment, and you have a very cool avatar!
Newbies Hospitality Director
I have removed/installed the mufflers on my 996 three different times using jack stands and I never needed to remove the bumper cover. I did, however, remove the wheels.
