19" Summer vs WinterTire Air Pressures
I'm wondering if people run different pressres on their 19" snowies (n-rated of course ) than they do for summers...Any advantages / dis advantages running different pressures than posted in the doorjam ?
The tire size does not change, so the air chamber size and load capacity stays the same. Run at placarded PSI and keep an eye on. Remember: tires gain/lose a pound for every 10 degrees difference in ambient temp.
Thanks for the responses.
10 degree variance from what "normal" temperature ?
I wonder what outside temperature those air pressure #'s that Porsche puts on the door are suppoed to be at as"normal" temperatures vary significantly around the world, and even in North AMerica
