Porsche Music Interface vs Dension
OK, from the title hopefully you can tell I'm a novice at this and have no clue. That said, can anyone tell me the difference between the two and if anyone has used the Porsche Music Interface for IPOD? I believe I prefer to go this way vs the cd changer-assuming this works -
TIA for any info
TIA for any info
Are you talking about adding to your 07 C4S? If so forget the Porsche add on, it's not interfacing with the PCM other than for volume!! it's an FM modulator, and an expensive one. The Dension offers full control of your i-pod through the PCM. Unless you are buying an 09, in which case it's fine!!
Ah Ha!!! Yes it was going in my 07- I asked the dealer how it worked and he told me you control it from the PCM unit and it list the songs, titles, etc. Thanks for the info.
