Anyong move from big red steels to PCCBs?
You are better off going with Brembo GTR brakes. Almost the same weight as the PCCBs for cheaper for a conversion.
Pads can be changed while at the track quite quickly as well.
Rotors that are on the car now as long as they are in good shape will do just fine. Or, yes, you can change to a different rotor, but make sure the calipers can be used with them or you'll end up changing those as well, which by most accounts, do not need changing as these are very good strong calipers.
Also, have the entire system flushed and filled with a racing brake fluid. Most use the Castrol SRF fluid.
I'm sure once you match pads to what track and type of driving you do, the brakes will work just fine and may surprise you.
As for shaving weight, look at exhaust systems, wheels, even tires... then more obvious things.
Regards,
Deanski
It was my understanding that the issue with PCCB rotors is from not changing pad frequently enough.
Oh - and as for that initial bite with PCCBs...it goes away after one session on a track. If you still have bite, they're not broken in.
