no lsd with PASM
I was playing around witht the buildder and I notice that you cannot have a lsd with PASm, its eithere or, but on a turbo you can add lsd with pasm. wy is that and how does that work with all wheel dr.
Newbies Hospitality Director
The S comes standard with PASM. Beyond that you have two choices :
Hope this helps.
1) LSD - Friction disc lock on rear axle. Pull - 22% and Push - 27%.
2) PASM Sport - Electronically variable active damping system with two manually selectable modes and limited slip rear differential lock. Ride height lowered by 20 mm.
On the base 997 (non-S) you have three choices:2) PASM Sport - Electronically variable active damping system with two manually selectable modes and limited slip rear differential lock. Ride height lowered by 20 mm.
1) PASM - Active management of suspension firmness and a ride height decrease of 10mm from the standard suspension.
2) LSD - (see above)
3) PASM Sport - (see above)
When you are in the configurator, click on the "i" in the info column and you will see the descriptions I have listed above. 2) LSD - (see above)
Hope this helps.
Yes you an have LSD with either the standard -10mm PASM or the P17 option with the -20mm Sport PASM. In either case you must also spec a set of 19" wheels.
Michael
Michael
I don't think that is true. The stock 4's come with LSD standard and 18" wheels. You can get them with PASM and stay with 18" wheels.
