WTB electronics for PSE
Old Sep 8, 2008 | 11:44 AM
BobbyB's Avatar
BobbyB
Default WTB electronics for PSE
Help, anyone out there who installed their PSE and choice not too install the electronics, and are willing to sell them, please let me know. I'm debating on purchasing the exhaust but need the electronics. Suncoast and other dealers have told me the electronics only come with the exhaust.
TIA
Old Sep 8, 2008 | 12:30 PM
AP997S's Avatar
AP997S
The 'electronics' you refer to is basically wiring harness(s) unless the PSE kit was destined from a non-Sport Chrono car. In that case a dash panel switch w/ wire harness was included.
I'm assuming the PSE you bought or are buying includes the vacuum solenoid that controls the vacuum valves on each muffler assembly.
You don't need the factory wiring harnesses to install the PSE. Most after factory PSE installs simply use a small toggle or rocker switch (usually installed in the ashtray compartment) to control the the vacuum solenoid. This allows the driver to control the PSE ('loud' vs. 'quiet').
On the other hand you can simply not wire up to the vacuum solenoid. This will place the PSE in the 'loud' mode all the time.
I hope this helps.
Good Luck!
Old Sep 8, 2008 | 01:37 PM
spicytuna's Avatar
spicytuna
Pm sent.
Old Sep 8, 2008 | 01:53 PM
BobbyB's Avatar
BobbyB
AP997S - thank you-your reply helps - I have the chrono -I will check what wiring I need to operate the solenoids -thanks again
Old Sep 8, 2008 | 03:13 PM
AP997S's Avatar
AP997S
The only wiring you'll need is for a +12 & -12 volt signal. A simple (2) wire harness or (1) wire if you take one of the solenoid terminals to chassis ground. What activates the solenoid is the presence or absence of +12 volts. Pretty simple and straightforward stuff.
