DE wheel/tire recommendations
The Penguin King
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
GT3 player par excellence
the sol'n has been presented in several posts.
you can buy cheap many times or get it right once.
do NOT run 19" period.
you want 9" front, rear can be 11", 11.5" or 12" depending on what tires you want to run. if you want 315 sections you need 12" for example.
the best wheel to get is CCW C10, forget the rest.
call CCW and talk to john. tell him your experience and use for the wheel. ask him for tire recommendation (most like nt01, ra1, or r888) then he can help you decide width for rear.
i have just about all the wheels under the sun and now run CCW exclusively with 4 sets.
But I notice "cheap" and "cheaper" in your your posts and hey, I like to save a buck as much as the next guy..... but at 150mph and in the track application, your tires and wheel type/fitment play a significant role.
If you are in traffic, at speed, going into a corner....... rarely do you think of how good a deal you got on what's keeping you on line.
Good luck with whatever you select.......and keep the shiny side up.
A lot of interesting advice. I pretty well knew before I started this thread that the consensus would be to buy some good aftermarket 18x11's. The ex-racer voice in my head says go that route and get the maximum performance package. However, the question really is, for someone who is only going to do two or three events a year, (in the lower run groups) if I get some OEM 18x10 takeoffs and mount something like 285/35's, will it at least be comparable to my stock 19 inch set-up.
There are not many tires in the 18" diameter that is the same overall height as the stock 19's. The 295/30/19 is 25.96 inches tall. The most similar is 275/35/18 (25.58" tall) which is commonly available in many DOT-R tires such as Toyo RA1, R888, Nitto NT01, etc. Most tire companies carry 285/30/18 or 295/30/18 which is too short. So I know there are more tire choices but I am now only limited to a 275 rear tire, if I want to keep the same overall height or at least as close to the original height.
JOHN52, what tires do you recommend in that size? There are not many choices.
So this is why I want to buy 19" wheels and then either try MPSC or Toyo R888 for tires. Also, I would like to address "cheap". What I mean is inexpensive not cheap in quality. I would love to but a set of forged wheels, but I can't afford it right now. So I would like to get the most out of the least amount spent. So an extra set of stock rims with the appropriate tire. I probably attend 4-5 events a year. I am in intermediate 2 run group.
I am inquiring about the same question. I have a 05 997S and having a hard time deciding between the oem 19x8, 19x11 versus a 18x8, 18x10 rim. There are cheaper 18 tires, but it seems you are limited to 285 width with a 10 inch wide rim and most tires only come in 265 and 275 wide. I assume a tire that 20 to 30 mm smaller going to effect handling/traction.
Every 997, 997S, GT3 driver I see who is seriously into DE has gone to size 18 The guys at CCW can confirm what I say.
www.ccwheel.com
Good luck.
The Penguin King
there are literally no good DE tires in 19". corsa and hoosier that's it. 888 is so so tire.
you have 997S. i am positive you can run 12" rear and 305 to 315, in hoosiers, r888 or nt-01.
diameter of tires doesn't have to match oem. just need to be close so you dont trigger all the computer faults. to that extent, you want the shortest tires for lower gearing.
Mooty,
That is correct and that is what I have been saying. Yes I would need a 12" wide wheel for 315 or 335. 305/30/18 is .6 inches shorter in height compared to stock. That's 2.5% off and could mess with ABS,PSM. You really should keep it under 2% variability. 305/35/18 exist Toyo RA1 and R888. This is a good size and really merits an 11" wide rim. Toyo lists that it would fit a 10" wide wheel, but that is going to bow out too much.
I dunno - yet ANOTHER set of rims for us northern guys that need to keep snow tires in the shed?
The OP was talking about DE's 2 or 3 times a year. That would be my case as well. Is it really that necessary to have a set of dedicated 18" track/wheels and tires in the shed for a few runs per year?
I'm looking at DE as a way to improve my driving skills and pleasure in driving the car, not as a method to cutting a racing edge or embracing an entire sport/hobby. Besides, I think I'd work toward a purpose-owned track car if wanted to go that route.
Are my street 19's and street tires really that bad to run on the track?
18's are a way to offset expense and get better track grip with R compounds. They will also follow you onto a track-prep car should you head down that path.
