Dash Noise
I just picked up an 2007 997 as a second owner. The car is great, but there's a stupid rattle/tapping that sounds like it is coming from the front dash, under the chrono clock. It sound like a wire or plastic plug is tapping against something metal.
I've taken it to 2 dealers and none of them can find the problem and do not seem to be willing to take apart the dash (don't really blame them as it may cause more sounds when returned). I've taken out the cup holders, ashtray, AC vent, radio, and AC controls all to find nothing! I've searched and thought it was the AC vent as it seems like a few people had this before. I did find that the door lock switch does shake and rattle a little but this was not it as I've driven the car with the whole thing out.
Any ideas on what could be loose?
Thanks!
Thanks!
Poseur
Another way to trouble-shoot this sort of thing is to have someone else drive the car while you focus upon isolating the noise source. I can't help but agree that this sort of thing can drive you nuts!
does anyone know how to remove the glovebox?
i had a similar rattle & had the dealer fix it under warranty. they took out the sport chrono - not saying this is definately the cause of the issue for you - and they repacked it with a bunch of felt tape & stuff. i don't really want to know, frankly.
i've had 3 rattles in 8 months fixed. i have been told this isn't so terribly unique but it seems a bit unique that my dealer is so cool about fixing them up right away.
not sure if this is related, but when turning right, i hear a sort of...rubbing/creaking coming from the right side of the dash. and only when TURNING right...never on turning wheel back to center, or turning left. i'm pretty sure it has to do with temperature and tolerances as i only hear it sometimes (altho, since it happens at odd times, i cant even narrow down whether its when car is warm on a cold day, or car is cold on a warm day, etc etc) . anyone else have this? ps, i do not have chrono.
While its happening, reach across to the passenger side and push on the dash (the part thats perpendicular to the ground). It may "click" into place....temporarily.
This fixes the problem I have....until i hit a pot hole and then it "un-clicks"
lather rinse repeat
lather rinse repeat
