CEL, misfire after softronic flash upgrade
so i finally flashed my 2005 c2 with softronic flash. drove the car and did not see a huge difference in the throttle response, actually i think my throttle response was better in stock , but i do see a slight better pull in mid range and as you reach 6000 to 7000. this was missing in the stock , but after couple of spirited drives, and one morning after the car sitting in the garrage for a ~week , after i backed the car i got a CEL, looked up the durametrics code. (codes below for misfire)
could this be the flash or something else its ironic how this happened few days after the flash upgade.
since then it has done this again once, i cleared the codes, got a new tanks of gas and this morning i drove the car to work and no code and no CEL, although at the work parking lot I did noticed on the durametric software- actual values menu while the car is running, i get 1 mis fire here and there on random cylinders, but no CEL , is that normal. any help would be appreciated, its driving me nuts.
moduleType = MotronicDME78
DTC Count = 5
Fault Number:P0300
Description:Misfiring
Repair Infomation:checksum error
DTC Count = 5
Fault Number:P0301
Description:Misfiring cylinder 1
DTC Count = 5
Fault Number:P0302
Description:Misfiring cylinder 2
DTC Count = 5
Fault Number:P0303
Description:Misfiring cylinder 3
DTC Count = 5
Fault Number:P0305
Description:Misfiring cylinder 5
DTC Count = 5
Fault Number:P0300
DTC Count = 5
Fault Number:P0301
DTC Count = 5
Fault Number:P0302
DTC Count = 5
Fault Number:P0303
DTC Count = 5
Fault Number:P0305
Did you email Scott at Softronic yet? That would be your best chance of help
