New Porsche IPOD connection review...
Today I installed the first Porsche IPOD connector that has been done in our shop. Overall my first impression was mixed... The connector that goes into the armrest is nice, I REALLY like the fact it gives you an IPOD connection and a 3.5mm headphone jack. I did see something i didnt like, it is RF modulated, as opposed to using the MOST loop... I must say, this disapointed me. But i understand this is a compromise to allow the retension of the cd changer. The install is much more involved than doing any of the aftermarket options, I have done NAV-TV, MO-BRIDGE etc.. Complete removal of the center console is necessary, and you lose your 12v power outlet in the armrest. It gets its power, ground, and remote signal from the radio where you need to unpin, crimp and re-pin the radio connector. And it uses a modulator box that you mount behind the PCM/CDR that goes in series with the antenna. and the harness from the center console connects to. Just like the old time cd-changers you have to tune to a certain station then the radio goes into AUX mode, the CDR has no control over the IPOD and i dont believe the PCM will either unless its a different kit, so you do all your inputs from the IPOD which I honestly believe will save some frustration on the user end, I have customers still trying to figure out the features of the aftermarket units. I was pleasntly surprised at the quality of the music, to me it sounded just as good as through the MOST loop.
Mark
Mark
Moderator !x4
Thanks Mark, very good review. I had the same setup although not as tidy as the OEM physically, the sound quality was OK until my current setup thru the MOST which is like night and day.
Thanks again, very usefull
Super Moderator
Needs More Cowbell
Needs More Cowbell
As a matter of fact, very early PCM code supported 2 CDC on the ring; if an 'unknown' device was detected, it was assumed to be a CDC......but those days are long gone.
This is only due to the fact that PAG did not want to have to pay for new PCM code and deploy it. You can have multiple 'CDC' units on the ring; one could be a CDC4, one could be an iPod....you would simply cycle thru the various 'CDC' units by pressing the CD button.
Mark
Super Moderator
Needs More Cowbell
Needs More Cowbell
These were my comments I sent to my dealer.
As you are aware recently I requested Porsche Azerbaijan to procure and install the Ipod adapter in my Cayenne. Right after the installation I found out what a useless piece of equipment Porsche has developed at such a high price: there is no functionality of the adapter whatsoever. You can not control Ipod by no means other than stop the car, open the armrest box, pull out the Ipod find a song, put it back and drive away – what a disappointment! In fact, it is not safe to have a such thing in a car!
Moreover, at that price there are a number of alternatives that have much better sound quality, e.g. Mobridge, Dension, etc. Another perfect example - an adapter I used to have in my 2002 BMW X5 – it was a $150 connector that gave full control over an Ipod through the stock audio system and steering wheel button – this was 6 years ago!
Therefore, I requested to remove this interface from my vehicle. Please pass on my comments to Porshce Exclusive and Tequipment department.
I agree you have to look before you buy, but there is a reasonable expectation that the Porsche item would be better than 1993 technology.
In other news, I was a passenger in a Honda Element last weekend which has full IPOD controls built right into the head unit. Lovely...
Last edited by Vitamin_J; 07-29-2008 at 12:57 PM. Reason: arrrgh, typing too fast.
Super Moderator
Needs More Cowbell
Needs More Cowbell
Super Moderator
Needs More Cowbell
Needs More Cowbell
However, PCM3.0 has addressed many of the 'creature comfort complaints' that have piled up over the years.
Widescreen touchscreen
Hard disk drive
Bluetooth
iPod
USB/CF
yadayada.
And, no, it's not retrofittable into PCM2.x vehicles (well actually it is, but Porsche won't allow it....sort of like Porsche not offering/allowing SAT radio in the Carreras/Boxsters....untils someone mentioned you can simply install the Cayenne SAT radio kit.....no names please)
Hard disk drive
Bluetooth
iPod
USB/CF
yadayada.
Hard disk drive
Bluetooth
iPod
USB/CF
yadayada.
Hard disk drive
Bluetooth
iPod
USB/CF
yadayada.
Super Moderator
Needs More Cowbell
Needs More Cowbell
